Results 1 to 6 of 6
    Caution;  Merge;  Workers Ahead! XTR External Cups on Race Face Cranks
    I just got some XTR external cups for my Race Face Atlas cranks and the inner plastic sleeve does not snug up like it did with the Race Face bearings.
    Do I need to get a Shimano inner sleeve?
    This is on a bike with a 73mm bottom bracket shell
    this is the part I am talking about
    Bad Case of the Mondays
    Reputation: Jdub's Avatar
    Quote Originally Posted by TXDirtDawg
    If it isn't snug, then I would say yes. I am using a set of DuraAce external cups on my XTR cranks. I had to run the spacer from the XTR bottom bracket to get my spacing right.
    Maybe take it to your LBS and eyeball it to see if it will work. I didn't know you could use different external cups on these cranks (i.e. RF on XTR or vice versa).
    got it figured out..... The non-drive side race Face bearing is longer than the XTR ones. Gotta get a Shimano inner sleeve and it should take care of it.
    Reputation: ORYX's Avatar
    May 2005
    Will the XTR bearings fix the problems being had with the RF cranks?
    My wife thinks I am nuts for spending this much on a bike. I tell her I think I am nuts for spending that much on her Diamond ring!
    853+29+1x24=Fun
    Reputation: kev0153's Avatar
    Sep 2004
    I might give this a shot. My 2nd set of RF bearings are starting to feel stiff.
    I found this page on universal cyles. They have a part called the "inner cover with "A" o-ring" I think that is what you need.
    http://www.universalcycles.com/shopp...&category=1574
