Results 1 to 16 of 16
    May 2012
    XTR Crankarm slipping when pedalling, possible to use no BB Spacer?
    Hi. I have a problem with my crankarm (non drive side) slipped out when i pedalled.
    When i check the crank shaft is halfway through. Is it possible for me to use only 1 bb spacer on the drive side and no bb spacer on the non drive side so that it bites the crank shaft.
    Im using BB90 Shimano.
    Crank is toast.
    Probably destroyed it, but a picture is worth a thousand words.
    Reputation: G-Choro's Avatar
    what is the width of your bottom bracket? if it's 73 mm, then yes. you should only be using one spacer on the drive side.
    Plays with tools
    Reputation: customfab's Avatar
    The BB spindle should be about 80% of the way through the non drive arm. If it was only half I wouldn't be surprised that it failed. I'd be picking up the phone to have a serious chat with whoever installed the crank. You might be able to get it back in action with some sleeve retaining compound, basically a heat sensitive glue, but that's going to be a crutch and last ditch effort.
    May 2012
    Quote Originally Posted by customfab View Post
    Thanks for the reply. Yes im using 68/73mm BB with 2 spacers on drive side and no spacer on the non drive side. The picture is below.
    XTR Crankarm slipping when pedalling, possible to use no BB Spacer?-img-20130501-wa0031.jpg
    XTR Crankarm slipping when pedalling, possible to use no BB Spacer?-img-20130501-wa0027.jpg
    Plays with tools
    What width bottom bracket she'll does that frame have? Looks like you have one spacer to many.
    One, it looks more like two..
    May 2012
    So its okay to have 1 spacer In drivetrain and no spacer on non drive train. Why is my shaft slipping? Before this same setup, could it be my cleats worn out? Using crankbrothers cleats.
    Te mortuo heres tibi sim?
    Quote Originally Posted by Slapshock View Post
    Because you don't have enough of the splines of the spindle engaged with the arm. Simple. You have one (or two) spacers too many.
    Run as few spacers as you need to get the right chainline, not have your arms/rings nailing your chain-stays, and not have your crank-arm falling off
    Why would your pedal cleats have anything to do with this?
    the catalan connection
    Reputation: What&son's Avatar
    If youre lucky and only have ruined the left crankarm (Im just assuming, since its aluminum vs steel of the spindle) you can get a replacement of the left arm only. A lot cheaper than a whole crankset.
    "Blessed is the man who, having nothing to say, abstains from giving us wordly evidence of the fact." George Elliot
    May 2012
    Quote Originally Posted by What&son View Post
    Oh really. Where can i get that? Any website to reccomend. Im from singapore.
    Plays with tools
    68mm BB's get 3 spacers, two on the drive and one on the non drive
    73mm BB's get 1 spacer on the drive side
    If you're using a E type FD, remove one spacer from the drive side.
    The BB spindle is long enough to accommodate all possible setups, you use the spacers to shim whatever shell your frame has to the maximum width. This isn't something that's open to interpretation.
    Since you brought up the thought of something else causing it are you sure the crank is slipping? Are the crank arms not 180 degrees apart? A slipping freehub or worn out chain/rings could cause a similar sensation.
    May 2012
    Hi. Thanks for the response.
    Yeap the crankarms is slipping because it detached from the bike itself and stuck under my feet.
    I will try to remove all spacer today because im using avanti competitor 29 team frame the width of the bb tube is big. Will report today without using any spacer.
    XTR Crankarm slipping when pedalling, possible to use no BB Spacer?-screenshot_2013-05-03-08-17-28.png
    In case if this could be any of a help, above posted is my geometry and im using 68/73 SMBB90
    Plays with tools
    I think this is the point that you need to take it to a competent mechanic. I get the feeling that you don't exactly understand what we're talking about and if you would like to salvage your gear it's time to bring in a professional.
    May 2012
    Emmmmmmm
  1. Pedalling fast and long is they key
    By Jaybo in forum Endurance XC Racing
    Last Post: 03-15-2013, 03:46 AM
  2. creaking while pedalling...
    By osokolo in forum Beginner's Corner
    Last Post: 09-12-2012, 01:12 PM
  3. back pedalling
    By Kenrow in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-29-2011, 06:44 AM
  4. Is there something wrong with my bike - pedalling backwards
    By Paladin54 in forum Beginner's Corner
    Last Post: 02-10-2011, 05:04 PM
  5. Any pedalling rides at SoMo tomorrow?
    By Jayem in forum Arizona
    Last Post: 01-16-2011, 12:27 AM
