• 04-30-2013
    Slapshock
    XTR Crankarm slipping when pedalling, possible to use no BB Spacer?
    Hi. I have a problem with my crankarm (non drive side) slipped out when i pedalled.
    When i check the crank shaft is halfway through. Is it possible for me to use only 1 bb spacer on the drive side and no bb spacer on the non drive side so that it bites the crank shaft.
    Im using BB90 Shimano.
  • 05-01-2013
    AlexRandall
    Crank is toast.
  • 05-01-2013
    wschruba
    Probably destroyed it, but a picture is worth a thousand words.
  • 05-01-2013
    G-Choro
    what is the width of your bottom bracket? if it's 73 mm, then yes. you should only be using one spacer on the drive side.
  • 05-01-2013
    customfab
    The BB spindle should be about 80% of the way through the non drive arm. If it was only half I wouldn't be surprised that it failed. I'd be picking up the phone to have a serious chat with whoever installed the crank. You might be able to get it back in action with some sleeve retaining compound, basically a heat sensitive glue, but that's going to be a crutch and last ditch effort.
  • 05-01-2013
    Slapshock
    Thanks for the reply. Yes im using 68/73mm BB with 2 spacers on drive side and no spacer on the non drive side. The picture is below.
    Attachment 795384
    Attachment 795386
  • 05-01-2013
    customfab
    What width bottom bracket she'll does that frame have? Looks like you have one spacer to many.
  • 05-01-2013
    patineto
    One, it looks more like two..
  • 05-02-2013
    Slapshock
    So its okay to have 1 spacer In drivetrain and no spacer on non drive train. Why is my shaft slipping? Before this same setup, could it be my cleats worn out? Using crankbrothers cleats.
  • 05-02-2013
    scrublover
    Because you don't have enough of the splines of the spindle engaged with the arm. Simple. You have one (or two) spacers too many.
    Run as few spacers as you need to get the right chainline, not have your arms/rings nailing your chain-stays, and not have your crank-arm falling off
    Why would your pedal cleats have anything to do with this?
  • 05-02-2013
    What&son
    If youre lucky and only have ruined the left crankarm (Im just assuming, since its aluminum vs steel of the spindle) you can get a replacement of the left arm only. A lot cheaper than a whole crankset.
  • 05-02-2013
    Slapshock
    Oh really. Where can i get that? Any website to reccomend. Im from singapore.
  • 05-02-2013
    customfab
    68mm BB's get 3 spacers, two on the drive and one on the non drive
    73mm BB's get 1 spacer on the drive side
    If you're using a E type FD, remove one spacer from the drive side.
    The BB spindle is long enough to accommodate all possible setups, you use the spacers to shim whatever shell your frame has to the maximum width. This isn't something that's open to interpretation.
    Since you brought up the thought of something else causing it are you sure the crank is slipping? Are the crank arms not 180 degrees apart? A slipping freehub or worn out chain/rings could cause a similar sensation.
  • 05-02-2013
    Slapshock
    Hi. Thanks for the response.
    Yeap the crankarms is slipping because it detached from the bike itself and stuck under my feet.
    I will try to remove all spacer today because im using avanti competitor 29 team frame the width of the bb tube is big. Will report today without using any spacer.
    Attachment 795626
    In case if this could be any of a help, above posted is my geometry and im using 68/73 SMBB90
  • 05-02-2013
    customfab
    I think this is the point that you need to take it to a competent mechanic. I get the feeling that you don't exactly understand what we're talking about and if you would like to salvage your gear it's time to bring in a professional.
  • 05-02-2013
    Slapshock
    Emmmmmmm
