    Reputation: justaguy's Avatar
    Jun 2005
    XTR chainring question
    Hey guys. I have XTR M960 crankset with 24 tooth small gear. I need to put a 22 tooth ring on. My question is...do I have to replace the middle ring as well?
    Seems like at the online sites, there is a middle ring for a 22 tooth, and a different ring for a 24 tooth.
    Thanks for the help.
    thecentralscrutinizer
    Reputation: mopartodd's Avatar
    No. It will work.
    2015 Kona JTS
    2014 Scott Scale 710
    2014 Giant Anthem 27.5
    ups and downs
    The only real difference in the middle ring between the one intended for 22 and 24T grannies is where the shift ramps are located, so the shifts from granny to middle might not be as crisp.
    If you've got lots of miles on the cranks you might want to consider replacing the middle ring/cassette and chain at the same time anyway.
    Jun 2005
    thanks
    Not many miles at all. Probably less than 300. I will just buy the granny for now. Think I will go with the BlackSpire.
    Thanks again
