Results 1 to 7 of 7
    XTR cassette, different cogs
    Anybody ever fit a 34T cog on an XTR Ti 8 speed cassette? I'm replacing my 12T & 14T with a 13T (lockring style) and adding a 34T cog. It looks like the spider carrier will act as a spacer between the 32T cog with no futher mods?
    Quote Originally Posted by browns110
    I did it. Bought the stuff from http://sheldonbrown.com/harris/hub.html. All you need is the 34T cog. You are right, the spider carrier acts like a spacer. I used a XT 11-30 8 speed and converted it to a 13-34 8 speed with a 26-30-34 spread at the top end. I love it and can't imagine why more people don't do it.
    Actually...
    Quote Originally Posted by anand
    you said that all you need is big cog? Don't you need a 13T cog that will accept a lockring(I hope so as I ordered one)? I'm converting a 12-32 to a 13-34 with 28-32-34 spread. I'm old and slow )
    All you need is a 13T with an attached spacer. The 13T on the XT 11-30 cassette already had this. I ordered a new one anyway so I used it but it was not required.
    You will love the mod. I am old and slow also but I still love to ride up all the hills.
    thats my red stapler
    Reputation: jimjo's Avatar
    when you get tired of that set up switch your chainrings out to 42 30 20 assuming you have a compact drive or any combinations you like go to one of the online gear calculators to seee what gear ratios youre actually using. I switched over to a custom ti cassette which goes 14 - 30 and with 20 / 30 gearing i have almost the same as your 22/34
    when the going gets tough the world gets reduced to one pedal stroke at a time
    I thought....
    Quote Originally Posted by jimjo
    of that, but didn't see any 20T chainrings offered for 4 bolt cranks? I looked before I went to cog changes on rear.
    yeah that might be a problem i specifically bought compact 58/94 bcd drive cranks to have a bigger availability of chainrings i think that 4 bolt are typically 62/94 whatever it is the inner bolt pattern is too large to go as small as 20t
  1. XTR cassette loose on CrossmaxSL
    By HTail in forum Wheels and Tires
    Last Post: 08-11-2004, 11:05 PM
  2. help-broken xtr 8 sp cassette
    By Francine in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-26-2004, 12:52 PM
  3. Does SRAM PC99 chain & SRAM PG-990 cassette work with 01 XTR??
    By LocoMotoMan in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-16-2004, 10:10 PM
  4. XTR cassette help
    By Ska in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-25-2004, 02:34 PM
  5. Ti 8spd XTR cassette model #'s ?
    By fz4vgq in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-25-2004, 12:02 PM
