Results 1 to 2 of 2
    XTR 960 Q-Factor, What is it?
    For XC outboard bearing cranks:
    FSA is 169mm
    Race Face told me over the phone that they have the lowest Q-factor of 166mm.
    A shimano Tech would not give me a clear answer - he told me some pointless number that measured only to the inside of the crank arm. What is the XTR 960 q-factor?
    Fsa
    Quote Originally Posted by Maxrep
    FSA is 169mm
    Fsa is 169mm, but keep in mind that you have to run pedal washers that are 1mm think on each side too, so make that 171mm total. I have short spindle ti eggbeaters to correct for the FSA q-factor, and it seems to work just fine. Feels like normal (I used to have the Race Face Deus with long spindle eggies).
    Its not for sure, but I heard XTR 960 cranks have a 170mm Q-factor. Just what I heard.
