Results 1 to 2 of 2
    XTR 952 rear derailleur slack issues
    I'm putting together my old bike and it has a XTR 952 rear der. I remember on drops and downhills the chain would go slack and I would look down and even hear the chain making a zipper noise to tighten back up. I am wondering if I need to replace the axle spring around the bolt? I'm just wondering before I go and spend the $. Thanks! I did search for a while, but most everyone just gets a new Der.
    I decided to take it apart; and it turns out the spring tension was on the lesser tensioned hole. I cleaned and re-greased and put the spring in the higher tension spot. I think that will do the trick! I will report back if it doesn't.
  1. Slack chain.... derailleur or freehub?
    By twilk in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-23-2012, 08:21 AM
  2. Rear Derailleur/Chain Issues
    By jaybear in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-08-2012, 06:23 PM
  3. rear derailleur slack when mounted onto hanger
    By lifanus in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-22-2012, 04:51 PM
  4. issues with sram rear derailleur and uzzi
    By cvega in forum Intense
    Last Post: 02-13-2012, 01:06 AM
  5. XO rear derailleur cable issues
    By kinsler in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-23-2011, 07:57 AM
