XTR 1x10 or XX1?
Should I wait for XX1 or just go 1x10? My bike is stating without a drivetrain. Is XX1 really worth the wait? No one seems to know when they will get any of the 168 Q factor GXP BB full kits in.
I'm in the same boat. tough decision
Hmm, didn't see that. It's a really good price too. I really want to support my LBS, but they have no idea when QBP or any of the other suppliers will have them in stock.
So does the XX1 take a specific BB other than BB30 or GXP?
The only reason to get the 11sp, is the flexibility of gearing choices once you go 1x. I'd guess that the chainring choices for a front XTR ring will be more limited than the XX1 crank. If the XTR tooth size choices work for you, then stick with the 10sp.
Rider
I am considering XX1 as well for a new build. The whole kit is going for anywhere from $980 up to $1250 from what I've seen, plus $60-$100 for the rear hub driver for various wheels. I am sure the prices will drop as time passes or Shimano releases something similar.
I am leaning towards a 1x10 setup with the xx1 crank and ring paired with a type 2 RD to keep the chain in line. Interestingly enough, after checking into prices, you can build a 1x10 setup with a x9 type 2 RD etc for quite a bit less. Comparing this setup to XX1, the weight difference is very small, around 100 grams or so, depending on cassette, chain etc. Has anybody else considered the same?
i've been running an xx1 set with the grip shifter for a few weeks now. the shifter may not be worked out yet, but the drive train is badass to this point. i was running a 2x10 xx setup on my previous bike. the granny gear is basically identical and i lose exactly one gear on the top end.
in the end, when i'm mashing the pedals at 25-30 mph i don't have one more gear. i almost never need that gear. if i'm doing 30 mph for any extended period of time i'm descending, and if i'm descending i'm using my brakes to control my speed more than my drive train.
the jumps between gears aren't weird in the least. it's tight and crisp through the entire range.
also, i've been running it without the chain guide since day 1 and haven't thrown the chain.
5 years one post
Awesome
I just got XX1 for my stumpy
No riding yet because of the weather but I am impressed with the quality
Its going to be a good riding year
 Originally Posted by Tone's
mate if theres grass on the wicket its time to play cricket.
Next time chop it for all its worth...
XTR 1x10 is more expensive than XX1?
If money is no issue then buy XTR now and XX1 in six months when your shop has it.
If money is an issue then get the XX1 crank and run it with whatever until you can get the cassette, shifter, derailleur.
I'm a big fan of 1x10 but late in a long ride I would like more gears. I'm doing XX1 a piece at a time as money allows. I have the XX1 cranks installed already with my other 1x10 stuff with XT brakes.
You could set up XTR now and add the other parts systematically down the road. Also you should be able to find XX1 for under a grand but you still need brakes and Shimano's are the best right now. XTR brakes would be awesome with the XX1 drivetrain.
Plant Powered Mountain Bike Racer.
 Originally Posted by TBarnaby
Dang. Had them. Was gonna pull t he trigger when I got home from work, but he was already out of the 168 Q factor GXP. No one can hang on to these for more than a day. Come on SRAM, pump these babies out. Don't release something in August and still not have any in January. Super lame.
 Originally Posted by SlowerJoe
5 years one post
Awesome
i will have more to say in 2018. enjoy the xx1.
I assume you are looking for the 170mm GXP ? I have the same issue / the LBS couldn't fine the GXP 170mm at any supplier.
I'm probably going to buy the crank from upgrade cycles and the rest from my LBS. The other option is to wait for the Specialized spider to come out which is meant to be in the next few weeks according to other mtbr posters.
If you can use 175mm they have the set here for $950:
SRAM XX1 Trigger Shift Kit-In-A-Box 175mm 166Q 32T GXP Crankset 10-42 11 speed; Bottom Bracket Not Included
Disclaimer: I've never ordered from upgrade cycles, so no idea how good they are at shipping on time etc.
EDIT: You were going to buy from ebay for $1180? You can buy each component separately for less than that online.
EDIT2: I ordered the cranks from upgrade cycle. It said it was in stock even after I added to my cart. They charged my credit card and didn't say anything about back order. A few days later I called up to see why it hadn't shipped and they said it was on back order, so I just cancelled it. Even after I got off the phone it only said back order if I added 9 units instead of 1. Pretty poor.
I just ordered from universal cycles instead. It was only a couple of $ more with the vip15 discount code. They shipped on the same day. I'll probably avoid upgrade cycles in the future.
I ordered my XX1 from Upgrade Cycle Works . Free shipping is VIA UPS and they are good about shipping as soon as stuff is instock. I had zero issue with them and have ordered several other items since. They are super friendly too. They are basically a QBP middle man, and my stuff came in a QBP box. They get them instock all the time so the wait is generally pretty short.
I've been riding XX1 for nearly 2 months now and I have to say it is worth every penny. Super quiet and the chain has never once come close to coming off. I was running XTR/X0 2x10 and I wouldn't go back! I've rode some of the roughest local trails and done a bunch of climbing and I have never once wish for a higher or lower gear.
I don't know why local shops can't tell you when QBP is supposed to see more XX1 inventory. They can look it up on the dealer website and see. Estimated arrival date for the rear D and crank is 2/1/13. Chain and shifter are looking at 3/15/13 and the cassette is in stock. I'm just missing the rear D and chain for my setup.
Where did you see it for $980? I'd buy that right now.
upgradecycle has them instock for under $1000. I paid $937 for my build kit in early December
https://www.upgradecycle.com/catalog.../result/?q=xx1
They did look it up, and yes they usually have an ETA on most items. However, on the full kits in a box they don't give an ETA. I was in the other day and they showed me. He then did the live chat with QBP and the rep said they weren't sure when they were getting more kits in a box, but said he thought it would be sometime in the next month. I need everything in the kit and they're giving me a sick deal on it, so it's worth waiting for. Just getting anxious. Want to ride, it's been spring weather here in CO.
A friend of mine and myself have had the xx1 set up on our bikes for over a month now and it is amazing stuff. It shifts accurate and the gearing is spot on, I never feel like i'm in the need for more gears, and it's amazingly quiet. There is never a thought of a dropped chain either, I couldn't imagine riding a 2x anything set up ever again, you will not be dissapointed.
2013 Trek Superfly 100 AL Pro(sold)
2013 Specialized Epic Marathon
Gorilla marketing only works when it's believable!
Dang, Sram is working these board harder than...
3 Floyd's Zombie Dust doing the posting last night.
 Originally Posted by Mr. Lynch
They're out too. As soon as you add to cart it says the item is back ordered. Dumb.
If they're gonna work it, tell us when we can expect to see a mass quantity dropped on us. Going 1x10, can't wait any longer. Maybe I'll give XX1 a try when it's actually attainable sometime this summer, or when shimano releases a 1x11.
the reason I got xx1 was because I was happy with the xo 10 speed gripshift I got for my fat bike
just to let you guys know Im not a fanboy I am running an xt front derailleur on my fatbike and an xt cassette
I had juicy 7 brakes "traded them for a case beer" think I got the better deal on that one
I sold my the reverb seat post
our trails are not ridable right now so I only had my XX1 on the road
it is quieter than my single speed "I bounced the bike around and no chain slap"
it shifts the same as my XO grip shift "nice and crisp"
if the chain stays on without a guide and it holds up well it is everything they say it will be
I will find out in march
till then its fat bike season
- You may not post replies
- You may not edit your posts
Forum Rules
