Results 1 to 8 of 8
    Work Shed...
    Reputation: Rootberry's Avatar
    Xtr 10 speed chain, broken connecting pins
    Just tried to install a new xtr 10 speed chain, but both of the connector pins broke halfway in. Only 2 are included, is this the only safe way to join the chain?
    It's not hip hop, it's electro.....
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Some have been using KMC links w/ XT, might be worth a try.
    New Shimano XT chains and powerlinks?
    Former Bike Wrench
    KMC, SRAM, or Connex 10 speed connectors should all work...I prefer the KMC version myself
    Mar 2011
    I am running the SRAM 10 speed power lock with a 10 speed Shimano chain no problem. I have heard the KMC is better - the only reason I haven't tried it is because the shop selling SRAM links is 400 meters away - the nearest shop selling KMC is 10 miles away....
    Old school BMXer
    Reputation: Blaster1200's Avatar
    Quote Originally Posted by Rootberry View Post
    How the hell are you breaking pins when installing them? Something tells me that you're doing it wrong.
    May the air be filled with tires!
    Bummer!
    Two suggestions:
    1. Go to a bike store and have them show you the proper way to join a chain
    2. Buy and use a Shimano chain tool and get some extra pins at the shop in return for their time
    Best of luck.
    Plays with tools
    Reputation: customfab's Avatar
    Quote Originally Posted by Blaster1200 View Post
    Second. I've broken the pin in the chain tool several times but I've never broken a Shimano install pin.
    Reputation: G-Choro's Avatar
    i'm using the KMC missing link. works great w/ the XTR chain.
