Results 1 to 2 of 2
    Keep on Rockin...
    Reputation: Miker J's Avatar
    Nov 2003
    XT or SLX 3x10 to 2x10 crank conversion/bashring...
    I'd like to run a 2x10 but with a 24-32 ring setup. Good deals can be had on the 3x10 cranksets.
    Like 9 speed cranksets, which were an easy coversion with a bashgard, can I do the same with the 3x10 stuff?
    Where can I get a light bashgaurd for this?
    Also, do the Shimano XT rear derailures work OK with a 22t front ring (supposedly they are designed to only go as low as 24t up front)?
    Thanks.
    Adding a bash to a 3x10 crank is exactly the same as with a 3x9.
    BBG makes a nice light bash ring, and it's only $18 shipped.
    If you're running a 11-36 cassette, a 24t ring should provide plenty of low end. The rear derailleur shouldn't have any problem with a 22t front, but the front derailleur might not shift as smooth and could give you some slight rub.
  1. 3x10 to 2x10 Conversion Assistance
    By aenima326 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-18-2014, 10:05 AM
  2. 2x10 and 3x10 crank...what's the difference
    By JQHansolo in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-30-2012, 06:39 AM
  3. X0 2x10 shifters with X0 3x10 Crank Set
    By teelow in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-03-2011, 02:54 PM
  4. 3x10 to 2x10 conversion.
    By rayzer in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-01-2011, 05:24 AM
