Results 1 to 9 of 9
    Just Ride !
    Reputation: C.M.S's Avatar
    XT shiters with ss cables Q
    http://cgi.ebay.com/Shimano-XT-Derai...item58860cf863
    My question i have is would the 600mm reach the rear deralleur on a large size frame FSR ?
    2004 S-Works enduro to be precise...
    Ummmm ATTEN Mods i meant shifters
    You either need a metric tape measure or a conversion calculator. 600mm = 23 5/8 inches.
    Just Ride !
    Quote Originally Posted by gmcttr
    sounds like that wouldnt even reach a front derailleor ...
    what are the sugegestions on were to get cable housings if i get a set of shifters with the ss cabels included ?
    ups and downs
    Those are intended for the run between the shifters and frame cable stops and then the shorter pieces is the RD loop. If you want to run full length rear derailleur housing just go with some bulk cable housing from your LBS or from these guys.
    Just Ride !
    Quote Originally Posted by rockyuphill
    Sounds cheaper to buy shifters with cables and then cable housing vs shiter pods and then geting a good set of shifter cable set ?
    Old man on a bike
    Quote Originally Posted by C.M.S
    What makes sense in the long run is buying bulk housing and cutting it to length, just like shops do. You will need tools to cut the housing to size, which is the bulk of the expense in doing your own (and you may already have sufficient tools, depends on your tool collection). Buying precut housing in my book is a waste. Some shifters come with housing and cables, some don't. Running full length housing is even better in my book.
    suum quique
    Just Ride !
    Quote Originally Posted by Bikinfoolferlife
    But then again is this anygood since i have nothing for brake set up yet.
    http://cgi.ebay.com/NEW-JAGWIRE-HYPE...item19b93663b5
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Good choise , sets for both shifters and brakes included.
    Just Ride !
    Quote Originally Posted by AZ.MTNS
    Just got an exact kit with free shipping for 26.99 So i saved a bit from the abouve prev link
    Hope there good LOL
