Results 1 to 5 of 5
    Feb 2012
    XT Shadow Plus rear derailleur question
    This new product is supposed to reduce/eliminate chain slap. Does this mean that I no longer need to put on my ugly chainstay protector if I installed one of these?
    BMF
    Oct 2007
    Depends on whether it reduces or eliminates as you wrote...
    Reputation: Trail_Blazer's Avatar
    May 2012
    Shadow will help on the average smaller trail bumps with, but on 2 foot drops or jumps it won't prevent chain slap.
    There is a new expensive model that has a "tension clutch" and it does prevent chain slap on most 2 foot drops.
    Feb 2012
    Quote Originally Posted by schristie11 View Post
    I believe you're speaking about the Shadow+. Are you using this already?
    Yes you still need a chainstay protector.
    The shadow plus adds tension to the chain below the chainstay, above the chainstay it would be the same and bounce around the same.
    I have the new xt shadow plus and still hear noise, for what that's worth, not sure where it's coming from, but the chain is still moving around a little.
