    Reputation: dumpy's Avatar
    Apr 2005
    xt rear derailleur pulley
    I recently took my derailleur pulleys out to clean and lube them. The upper pulley's bushing's covers came off. It claims on the side that it is a "sealed ceramic bushing", but it obviously isn't (or isn't anymore). I reassembled the bushing the best that I could. I'm fairly new to doing my own wrenching, so I am not sure if this should have happened or not. I am wondering if my no longer sealed bushing will still be effective or if I should replace it. Any advice would be greatly appreciated. Thanks
    Chrome Toaster
    Reputation: Hecubus's Avatar
    The new XT's apparently have bearings on both pulleys. The older models had a ceramic bushing in the top one. Don't worry, the covers come of when you dissaseble it. The pulley bolt is what keeps everything in place. Just make sure you put everything that came off back were it came from and you're good to go.
    Apr 2005
    Quote Originally Posted by Hecubus
    Great, thats what I assumed, even though it said it was "sealed", the construction of it led me to believe that it wasn't truly. I got it back together and back in so hopefully it should hold. Thanks for the help.
    Reputation: GearHead's Avatar
    Dec 2004
    Quote Originally Posted by dumpy
    I actually find that it is good to take apart the top pulley when cleaning up the rear derailleur and add a small grease film to the ceramic bushing parts. This helps to make them run squeak free.
  1. XT rear derailleur on a 7 speed?
    By dagimp in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-02-2005, 02:06 PM
  2. If you need to know this.
    By KevinVokeyJ24 in forum General Discussion
    Last Post: 12-24-2004, 09:40 AM
  3. XT M760sgs rear derailleur issues
    By AL29er in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-31-2004, 10:44 AM
  4. Question about a new rear Derailleur, XT vs XTR.
    By Dean in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-09-2004, 07:31 AM
  5. Shifter compatibility of Shimano XT rear derailleur
    By bobalouie76 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-12-2004, 10:59 AM
