Results 1 to 7 of 7
    Living the Dream
    Reputation: Alpenglow's Avatar
    Are xt m785 2x10 chainrings compatible with xtr m980 cranks?
    Just trying to save a little money on replacement rings.
    "And I shout that your all fakes and you should have seen the look on your face"
    Living the Dream
    I am also hoping to run a 24/38 AM setup on my xtr 980 26/38 crankset. I think that this will work just looking for some confirmation. I searched this forum and internet and could not find anything conclusive. Thanks for any help.
    More Torque
    Reputation: Diesel~'s Avatar
    The big ring should fit with no issues. Current XTR small rings have a 2mm offset, and unless the 785 small CR has that as well (770 and prior did not), you will need a 2mm spacer to put between the small CR and the crankset.
    I've tried 24/36 and 26/38, with Shimano rings on the XTR 970 and 980 cranks with good results. Never tried a 14 tooth jump however.
    In case anyone else searches this thread and wants info on FD/Shifter compatibility, here is what I found:
    26/38 works fine with 3x FD and shifter in 3x mode. Looks a little odd though. I would prefer to run a 2x FD with this setup, but my frame will not allow the FD to be lowered enough.
    24/36 works fine with 2x FD and shifter in 2x mode. Looks just right. I did not try the 3x FD with this, but I suspect that it would work just fine, while looking a bit odd.
    -D
    Living the Dream
    Thanks--do you have a part number for the spacer? BTW, all the info I could find said a 14 tooth jump was fine, but that was the maximum recommended. They sell an XT AM 785 crankset that is 24/38
    Shimano XT M785 10 Speed 24/38 Crankset with Bottom Bracket in Tree Fort Bikes Cranks (cat93)
    I ordered the 24/38 chainrings last night. I will order the spacers also if required.
    Thanks for the help!
    More Torque
    I picked mine up locally, but I'm pretty sure that they are the wheels mfg CS-2.2. Don't get the CS-2, as the ID is too large.
    -D
    Living the Dream
    Diesel thanks for the help. Do you know if the 24 inch blackspire M980 ring will work without having to mess with spacers? Blackspire - SuperPro M980X Chainrings | Blackspire
    Also, when you used spacers, did you have to order new chainrings as well?
    More Torque
    Quote Originally Posted by Alpenglow View Post
    The 24T M980 ring should work w/o spacers, unless they are taking a regular ring and providing spacers along with it, which I doubt. The comments on the page, regarding the fitment for XT and SLX for middle/big also make it look like the small CR is the correct XTR specific one.
    When I used spacers, it was to mount an XT or SLX small CR. I will often go steel on the small ring for durability.
    -D
  1. Are XT M785 2x10 chainrings compatible with xtr m980 cranks?
    By Alpenglow in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-20-2013, 05:22 PM
  2. 38/26 t M980 XTR Chainrings on M970 XTR Cranks
    By Spin Cycle in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-21-2012, 09:22 AM
  3. Can I use XT M785 2x10 chainrings on my XT M770 crankset?
    By FireLikeIYA in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-13-2012, 01:59 PM
  4. XTR M980 2x10 chainrings
    By shanem in forum Shimano
    Last Post: 03-07-2012, 11:28 AM
  5. m760 cranks and m771 chainrings compatible?
    By corleone in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-23-2011, 02:19 PM
Members who have read this thread: 4
