Results 1 to 3 of 3
    XT M752 Crank bolt help
    Hello I am wondering if it matters what crank bolt i use with my cranks. I have been using two bolts that were in the random bolt box at the lbs. However the non drive crank came loose. I have tightened it down again but there still seems to be some play. The crank bolt does seem to be pretty far into the crank. Is there a right or a wrong bolt?
    g3h6o3
    Reputation: PissedOffCil's Avatar
    Oct 2007
    what bolts are you talking about? The pinch bolts?
    If so, any long enough M5 with a small enough head should be fine
    I have a tendency to change the pinch bolts myself. Shimano bolts are made of butter. The head never completely strips but still gets digged in.
    Check out my SportTracks plugins for some training aid software.
    i think the bolts are fine now. It is something in the pedal. I think
