Results 1 to 2 of 2
    XT Clutch Failure or Adjustment Issue?
    I have a Cannondale Trigger 29er1 that came with an XT clutch rear derailleur, I think believe it's an XT M786. For the first few months it has worked great, the clutch feature has been awesome. Recently I started to get some chain slap. I found that there was some front to rear play in the cage before the resistance of the clutch kicked in. I opened it up and tightened the adjustment a little bit which seemed to remedy that, for a few miles of riding. It feels like the clutch still works, but you can move the cage forward a 1/4-3/8" before the resistance of the clutch is felt. Do these need frequent adjustment or do I have an issue with this thing that I should get warrantied?
    After some further observation it seems there is play in the P-Pivot before there is any spring tension or clutch action. I switched off the clutch and the same play still exists before there is spring tension against the cage, the same play is there with the clutch on. Also if I shift from the smaller rear cogs to the largest (36 tooth) the clutch seems to work. However, if I shift down the play is there again.
    Any ideas?
  1. Shimano Zee Clutch Lever keeps coming loose turning clutch off - advice?
    By coursemyhorse in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-22-2017, 04:01 AM
  2. front derailleur adjustment issue
    By BigE610 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-29-2013, 02:32 PM
  3. DBair - LSC/LSR adjustment issue
    By pizon in forum Shocks and Suspension
    Last Post: 04-29-2013, 06:53 AM
  4. BB5 adjustment issue
    By deceown in forum Brake Time
    Last Post: 05-10-2011, 09:11 PM
  5. B screw adjustment issue
    By cobra_280z in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-04-2011, 09:27 AM
