Results 1 to 9 of 9
    Dec 2005
    XT 8Spd Pods With 9SPD XT Derailluer
    Can I use a new 9 speed XT rear Derailluer with older 8spd shifter pods ?
    Freshly Fujified
    Reputation: Call_me_Clyde's Avatar
    You should be OK
    Just make sure it's not a rapid rise derailleur, as the shifting will be opposite (e.g 8 on your shift indicator will be 1 on the cassette, and vice versa). I am running a set of XT integrated 8 speed shifter/levers with a 9 speed LX derailleur and it's fine.
    FWIW, if you want an 8 speed XT derailleur, you can still get them new from places like jonesbikes on ebay. They also have a brick and morar store in CA if you don't care to buy online.
    Best wishes,
    Bob
    'If Wal-Mart sold parachutes, who would jump?' Frank Havnoonian (quoting his father) Drexel Hill Cyclery
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    No problem, that will work fine.
    Chrome Toaster
    Reputation: Hecubus's Avatar
    8 speed and 9 speed derailleurs are one and the same rapid rise or high normal. The total cassette spacing for 8 and 9 speed is the same and since the indexing is performed by the shifter the derailleur has no impact.
    uber-lurker
    Quote Originally Posted by Hecubus
    Is this also true for 7 speed derailleurs, or do they not travel enough (even with limit screws maxed out) to reach all nine gears?
    Thanks.
    Mantis, Paramount, Campy
    Reputation: Shayne's Avatar
    Seven spd derailleurs will work fine too.
    Reputation: wddamf's Avatar
    The derailleur doesn't know what travel it is - it just does what the shifter cable tells it to do - so they all work on all cassettes. The shifter makes the decisions.
    uber-lurker
    Quote Originally Posted by wddamf
    Understood - I thought maybe the parallelogram of the 7 speed rear might be too short for the as-yet-unthought-of additional width of the 8/9 speed cassette.
    But a 7 speed rear won't work on all cassettes, correct? They still must stay within certain max and min teeth? Or is that just a matter of cage length?
    Thanks for any clarification.
    That Is Just A Matter Of Cage Length
    Or rather a matter of which gears you shift into.
