Results 1 to 15 of 15
    Reputation: Sweeney's Avatar
    Nov 2006
    XT 771Rear Dérailleur, no adjuster, what gives?
    Last week I trashed my XT 760 RD and my dérailleur hanger. I got the now parts (XT 771RD) yesterday and went to work on it today. I put on the new hanger and the RD and saw that I didn't have an adjuster. No problem, I thought, I'd take it off the old one. No way. I doesn't use one. What gives!? How do you fine tune your shifting with a new XT RD?
    Reputation: sanjuro's Avatar
    Sep 2004
    The same way you do a SRAM?
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by Sweeney
    For better or worse Both Shimano and SRAM have stopped putting barrel adjusters on their mtb dérailleurs.
    mtbtires.com
    Nov 2006
    It's almost funny, in their blurb it says " thirty grams lighter than the previous model''. That's the weight of the adjuster. So seriously, what are you supposed to do; just put up with sloppy shifting. I'll tell you what I'm doing, I'm getting another 760 RD.
    Fine tune the shifting with the adjuster coming off the shifter.
    Dec 1998
    The adjusters do not weigh that much.
    As others have implied, use the adjuster on the flatbar shifter.
    Since I use dropbars, I have to add an inline adjuster or use road RDs
    mtbtires.com
    The reason i believe they have removed them is, they used to bend easy and rust. If you need to adjust your gears alot with the barrel adjusters your gears are either not set up right or worn out.
    I must admit that on my old Derailleur I used to like the barrel adjuster it was very easy to use. Since getting a shadow Derailleur and not having it I thought this is going to be a pain in the butt but soon got used to not worrying about it as I now use the barrel adjuster on the bars. However since changed over to Gore cable system for shifting I have found that once I set the limit screws I have never had to touch the barrel adjusters again. Is the Gore cables pre stretched or just don't stretch because I have no idea why I have had no need to touch the adjusters. Still I'm not complaining if it's been Gore's doing great or maybe I'm a better mechanic than I first thought I was.
    Nov 2006
    '' If you need to adjust your gears alot with the barrel adjusters your gears are either not set up right or worn out. ''
    I don't remember saying that I have to adjust my cables a lot. I just want to set it and forget it. The adjuster on my shifter doesn't look as fine as I want . I just sent the XT771 dérailleur back and ordered a 760. The savings almost pays for the shipping and I have what I want. In the future, I guess I'll have to look at long cage Ulrtega RD's.
    By the way, I've never had a RD adjuster rust out or bend. Maybe I'm just lucky.
    More Torque
    Reputation: Diesel~'s Avatar
    A buddy of mine uses one of these in his XTR RD.
    meh....
    Reputation: Monte's Avatar
    Quote Originally Posted by Elliott_MBR
    You're kidding, right? You use the barrel adjusters to set up the gears correctly, then it might need a touch once and a while.
    Shifter pods have adjuster barrels. Newer high end derailleurs don't have the any more to shave weight and to make the cable go in more direct.
    Jan 2009
    i've always found the barrel adjuster on the shifters (at least with gripshift shifters) to more fine tuned than the barrel adjuster on the derailleur itself.
    Reputation: fixbikeguy's Avatar
    Barrel adjusters on derailleurs break. There is no way to avoid it, one good hit and they are done. Thankfully they are now gone on nicer units and now we just use the shifter ones to do the fine tuning.
    Reputation: boomn's Avatar
    I never understood the reason for barrel adjusters on both ends of the cable. Just seems redundant
