Results 1 to 5 of 5
    Reputation: 02_NRS's Avatar
    xt 760 crank spindle spins-not the O.B. bearing.
    on the non-drive side I see wear marks on the spindle where it is spinning&not the outboard bearing.anyone find an EZ cure?
    Old school BMXer
    Reputation: Blaster1200's Avatar
    May the air be filled with tires!
    Quote Originally Posted by '02 NRS
    Repair/Replace the bearing?
    Can you spin the bearing with the cranks pulled out?
    It's the axle
    Reputation: Gregg K's Avatar
    Been there. 03 NRS AIR.
    A couple of years ago I pulled it apart and managed to get it turning again. Cleaned it up, and put it back on. It worked for a while. Then seized up again. I got a new set after riding home with the crank axle spinning in the bearing.
    It's the water on the inside of the bike that did mine in. It gets in through the seatpost, and steering tube. Then it gets into the bottom bracket area.
    ob bearings/
    thanks for the tips/they seem to spin OK by hand but as you exp.,could be time for R&R.enduro seal kit appears worth a try also.......
  1. ENO crank & spindle length?
    By cobblestone in forum Singlespeed
    Last Post: 08-29-2006, 05:35 AM
  2. Crank/BB spindle question
    By dirt_donkey in forum Singlespeed
    Last Post: 11-21-2005, 05:14 AM
  3. Crank Bros. shorter Ti Spindle
    By sgt_hedgehog in forum Weight Weenies
    Last Post: 10-16-2005, 04:23 PM
  4. Crank + Spindle = Chainline?
    By Live_Wire in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-28-2004, 10:06 AM
  5. XT crank and spindle question
    By nab in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-18-2004, 12:35 PM
