Results 1 to 5 of 5
    Reputation: ccornacc's Avatar
    X9 2x10 with XT 11-36 Cassette?
    Hello All,
    Has anyone tried a SRAM 2x10 crank set, PG 1070 Chain and an XT 11-36 10 spd cassette?
    I am currently running this and there seems to be some chain rubbing on the side of cassette/chain interface.
    Does anyone know if there is different chain widths and cassette spacing between the SRAM and Shimano 10 spd drive trains that could be causing this?
    Reputation: boomn's Avatar
    yes, I believe the Shimano 10spd cassettes are designed to be used with Shimano 10spd chains that are designed with a specific inner and outer side to the chain
    Never trust a fart
    Reputation: frdfandc's Avatar
    IIRC the Shimano 10 speed cassette gears are wider than the Sram 10 speed stuff, so a Shimano chain will be required.
    So I could use a shimano 10sp chain and 10 spd cassette with the SRAM 2x10 Crankset and not have any issues?
    Never trust a fart
    Should work just fine.
