Results 1 to 8 of 8
Thread: x7 rear
    x7 rear
    currently have a Sram X.7 Rear Derailleur 2010 - Medium Cage (Black)
    what derailleur do you recommend for my set up, i need to replace mine.
    SRAM 9 Speed PG-990 Cassette 11-34
    Blackspire Stinger Chain Tensioner - ISCG 05 frame
    Race Face Evolve DH Crankset 175mm 83mm 24/36/Bash
    should i stick with a x7 mid? or spend the extra cash for a x9 also should i stick with mid?
    Reputation: JSumner13's Avatar
    It really depends on your budget. You'll probably notice zero to very little performance difference between X7 and X9.....X9 will save you a few grams though. The question you have to ask yourself is if the weight difference is wort the extra $$$$.
    Reputation: boomn's Avatar
    Upgrading to an X.9 shifter will make a bigger difference than upgrading the rear derailleur, but even that isn't a huge difference.
    Former Bike Wrench
    Quote Originally Posted by boomn
    What he said...almost no difference at the derailleur, quite a bit of difference in the trigger shifters.
    Never trust a fart
    Reputation: frdfandc's Avatar
    Stick with the X7 derailleur. Upgrade the shifters.
    okay awesome! thanks, the shifters i have are only x5 so i really need an upgrade then haha. also any advice on the size? mid?
    Since your not running a bit ring (44t) a medium cage RD will be your best bet.
    just picked up some x9 shifters on chainlove.com hell yeah!
