    Will these parts work for a switch to 1x10?
    I want to switch to a 1x10 setup and Iíve been reading lots and Iím ready to buy the parts I need but Iím not 100% sure Iím picking the right parts. If someone could let me know if what Iím planning to buy will work, thatíd be great.
    I currently have:
    • 2009 Yeti 575
    • Shimano XT cranks
    • 2x9 setup, 24-32 front, 11-34 rear
    • SRAM X9 shifter and derailleur for the rear
    Iím planning to buy:
    • Shimano XT M771 10 Speed Cassette - 11-36
    • Shimano XT M786 Shadow+ 10 Speed Rear Mech - Medium Cage
    • Shimano Deore XT HG94 HGX 10 Speed Chain - 114 Links
    • Shimano XT M770 10 Speed Trigger Shifter - LH Front
    • Wolftooth 104 BCD x 30T ring up front (Wolftooth site says ďthe 30T chainring is threaded and has a 48 mm chainline. All other rings have 50mm chainline.Ē, Does that make any difference for me?)
    Iím happy to consider other front rings than the Wolftooth if there might be a better option for me. Iím tempted to go with a 28T in the front as I have a lot of steep climbs around here (Whistler/Squamish/North Shore) and my legs arenítí the strongest but maybe a 30T will be fine and just make me stronger. Also, is 104 BCD the correct size for the front ring?
    meow meow
    Reputation: b-kul's Avatar
    you will be all set.
    dwt
    dwt is offline
    Reputation: dwt's Avatar
    Quote Originally Posted by Jave View Post
    I currently have:
    • 2009 Yeti 575
    • Shimano XT cranks
    Yes that crank is 104bcd. AFAIK, the smallest ring that will fit 104bcd spider is 30T. 30T is what I run on my 29'er and with wagon wheels I never spin out in 30:11; 30:36 as a low is doable, but I might spring for a General Lee 11-40 cassette adapter
    The WT ring has the same teeth pattern as the SRAM XX1 rings, which when coupled with clutch RD, will hold your chain on without a chain retention device. A big plus
    Old enough to know better. And old enough not to care. Best age to be.
    Reputation: DriverB's Avatar
    Apr 2014
    A bit late, but I think you may want to get a rear trigger shifter since you are going 1x10, instead of a front? I am working on a similar conversion currently.
    Marin County, CA
  1. will this 1x10 conversion work
    By FlowMaster23 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-14-2013, 04:30 PM
  2. PAID SPAM 1X10 Parts: XCX Guide XO Rear Derailleur, HOMEBREWED rings, cranks and more
    By ryguy135 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-25-2013, 05:04 AM
  3. Parts list for 1x10 coversion checklist
    By bigdog100 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-07-2012, 07:03 AM
  4. will this cheap XTR work for 1x10?
    By RTM in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-15-2012, 11:13 AM
  5. Replies: 0
    Last Post: 01-21-2012, 08:59 PM
