Will a Shimano XTR SIS Shift Cable Set, listed as ATB, fit on an MTB? Thank you
Here's the item's specs:
  • Complete Mountain Bike Gear Cable Set
  • Polymer Sheath Lined Outer Casing
  • Includes Inners, Outers and End Caps
This complete gear cable set is designed to suit the top-of-the-range XTR gears. Fitting new gears or completely overhauling your gear cabling couldn't be easier - everything you need in one pack. Outer casing is lined with a polymer sheath to assist with the smooth operation of the inner wire.
High quality inner wire leaves a smooth surface for less friction, and stainless steel provides smooth shifting and higher corrosion resistance. The outer casing is lubricated internally along its length with low-friction silicon grease to reduce cable friction. Special construction process makes for an axially stiff outer casing that transmits shifting movements accurately and quickly.
Includes 1.2 mm inner wires (2 x 2100mm), and grey 4 mm outer casing for a complete bike (2 x 600 mm, 2 x 300 mm, and 1 x 340 mm), and all end caps.
Btw, I searched the internet & closest i came up with is this link What is an 'ATB' bicycle? Is it the same as 'MTB' (for the purposes of buying mudguards)? - Yahoo! UK & Ireland Answers
