Results 1 to 9 of 9
    Jun 2013
    Idea! Will old 8 speed shifter work with 9 speed cassette?
    Seems like Shimano's rep was wrong when he told me my XTR M910 shifter is 9 speed. From the info i'm gathering online it looks like it is 8 speed, especially after an ebay seller who is selling the same XTR M910 shifters told me it is 8 speed Shimano XTR M910 Shifters for Vintage Mountain Bike MTB Brake Levers | eBay. I posted 2 pics of my shifter. I see 8 positions for the "red gear-marker" in the pics. Please tell me if it is 8 speed or 9 speed. Thank you very much.
    PS. I bought a new XT 9 speed cassette. It will arrive soon. If the XTR M910 shifter is 8 speed, will the new XT cassette work with the old XTR shifters? Should i return the 9 speed XT cassette when it arrives & buy an 8 speed cassette? Thank you
    Attached Thumbnails Attached Thumbnails Will old 8 speed shifter work with 9 speed cassette?-img_0453-forums.jpg
    ups and downs
    Nope, different spacing between the cogs on 8 and 9 speed cassettes. All of the 8 speed stuff is self compatible, and the 9 speed stuff is all self compatible, so if you can find an 8 speed cassette these shifters should work fine with it.
    Jun 2013
    Quote Originally Posted by rockyuphill View Post
    Ty. If i go with the 8 speed set-up, a 9 speed chain won't work right? (Because i already got a KMC 9 speed chain arriving too)
    Reputation: mitzikatzi's Avatar
    The 9 speed chain will work on the 8 speed system.
    Read Sheldon Brown.
    Duct tape iz like teh Force. It has a Lite side and a Dark side and it holdz the Universe together.
    Jun 2013
    Quote Originally Posted by mitzikatzi View Post
    Read Sheldon Brown.
    Ty mitzikatzi. I found 6-speed, 7-speed, 8-speed, 9-speed, 10-speed, 11-speed? "As you go to more sprockets on the cassette, you need a narrower chain. However, using a chain one size narrower than standard rarely presents any problem. Thus, you can use a "9-speed" chain with a 7-speed or 8-speed system, or a "10-speed" chain with a 9-speed system. This is not the ideal approach -- shifting may not be quite as smooth -- but it's workable."
    ups and downs
    The only issue you might have with a 9 speed chain on an 8 speed cassette is if you have really sandy mud, the narrower chain is more prone to mud related chain suck/chain wrap.
    Jun 2013
    Ty. I decided to try the 9 speed chain on an 8 speed cassette (looking for 8 speed cassette now). If i don't feel it's smooth enough for me, i'll buy an 8 speed chain.
    The outside measurement of a 8 speed chain is more than a 9 speed chain.
    This means a 8spd chain can not be used on a 9spd cassette the gap between the cogs is too close. An 9spd chain will fit on a 8spd cassette.
    8spd 7.2mm or 3/32" vs 9spd 6.6mm 11/128"
    The "internal" measurement" of a 8spd and 9spd chain is very close. I just measured a 8 spd and a 9 spd connex chain (with cheap plastic verniers hence the very close).
    9 speed chains work fine on a 8spd cassette. I have used a 9spd chain on a 7speed cassette and it works well.
    Cheaper chains are sold as 6,7 and 8 speed.
    Connex 8-speed bicycle chains 1/2 "x 3/32"
    All bicycle chains of this series can be applied to all 8 -, 7 - and use 6-speed switching systems
    Chains only need to be narrow enough to clear the cogs on the cassette.
    This topic has be answered on these forums before.
    Jun 2013
    @mitzikatzi, thanx again
  1. Will an 8 speed rear derailleur work with a 9 speed shifter and cassette?
    By CyclesnIPAs in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-31-2017, 04:35 PM
  2. Will XT M772 rear der. 9 speed work with 8 speed shifter/cassette?
    By jh_on_the_cape in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-08-2013, 06:40 AM
  3. 2 speed VS 3 speed shifter on a 2 speed crank??
    By 2000Z3M in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-18-2012, 11:46 AM
  4. Will 9-speed X0 RD work with 36t cassette?
    By Cayenne_Pepa in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-06-2012, 02:25 PM
  5. Will Shimano Deore RD-M592 work with 8 speed cassette?
    By rja in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-01-2011, 12:37 PM
