Results 1 to 11 of 11
    Aug 2005
    Will an 11 Speed GX Der. work with an 11-32t cassette?
    I'm building a gravel/adventure bike and currently am piecing together a drivetrain with some new parts and some I already have. I have a GX 11 speed shifter and an 11-32 11 speed cassette. Can I use a GX rear der. or does the GX only do wide range cassettes? Its also going to be a 1 x set up. Thanks.
    2016 Santa Cruz Hightower 29er
    2016 Chromag Surface 27.5+
    2013 Transition TransAM 29er
    2017 Motobecane Lurch FS 26 fat
    Reputation: Lone Rager's Avatar
    Dec 2013
    Should work. The GX RD uses offset of the upper jockey wheel to track changes in cog diameter rather than using a slanted parallelogram which follows the cone angle of a cassette. This works for 1x as the change in chain takeup is solely due to the cassette.
    Do the math.
    Aug 2005
    Thanks man, your expertise is appreciated.
    Jan 2009
    Quote Originally Posted by Lone Rager View Post
    Assuming the OP has a "1X" GX... there's a "2X" too in both med and long cage
    Edit: oops maybe I misread and the OP only has the shifter at the moment
    [WTB] 1987 Cannondale SM800, 20", Pink with airbrushed graphics.
    Jan 2009
    Quote Originally Posted by J_Westy View Post
    If the OP is indeed buying the derailleur, this could be and option too:
    https://www.sram.com/sram/road/produ...2uq11omylskdxc
    Aug 2005
    Yes. I currently have GX shifter and an 11-32 11 speed cassette. Need a rear der.
    I didn't know SRAM made wide range road rear derailleur. I assume that works with a GX shifter?
    Jan 2009
    Quote Originally Posted by VTSession View Post
    It should. My newest bike came oppositely equipped with above bar "S" road shifters with a GX rear derailleur.
    Aug 2005
    Ordered. Thanks again for the suggestion, man
    Aug 2005
    For those who are curious - My 11 speed set up with a GX shifter, Rival 22 rear derailleur and 11-32 cassette works great as a gravel/adventure bike set up.
    Jan 2009
    Pictures!
    Aug 2005
    Pictures!
    Last parts are trickling in today and I'll have completed pics later. Kinda excited to do some gravel grinding out my front door!
  1. Will Shimano M780 10 speed R der work with Deore 9 speed shifters?
    By shwndh in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-14-2015, 08:32 PM
  2. 32T Bash Ring work on 32T Raceface NW Ring?
    By V8Interceptor in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-22-2015, 08:06 AM
  3. 11-32t, 8 speed rear cassette?
    By New Guy in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-11-2013, 07:52 AM
  4. Replies: 10
    Last Post: 06-25-2013, 02:55 PM
  5. Will XT M772 rear der. 9 speed work with 8 speed shifter/cassette?
    By jh_on_the_cape in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-08-2013, 06:40 AM
