Results 1 to 8 of 8
    Saving lives with knives.
    Reputation: frank daleview's Avatar
    Wierd Vibration coming from drive train
    I recently installed a new set of Cranks (Shimano FCR700 compact road cranks), a new cassette (shimano ultegra 9 12-25), and a new chain (sram 991 hollow pin) on my Cannondale road bike. I noticed a vibration during hard efforts in the big ring during the 2-5 o'clock positions on the crank. I know this an mtb forum, but I know a lot of you also ride road bikes, and the people on the road forum seem a little less technically oriented.
    As far as I can tell there is no play in the cranks or cassette.
    Any help would be sincerely appreciated!
    Formerly known as iceaxe
    Nov 2008
    We're talking high frequency vibration here, not a few creaks or clicks, right?
    Give it a chance to break in. Imperceptable flaws on the cassette cogs need to be worn off. After a few miles the chain and cassette will wear together to a perfect match, and it should run smoother. Your choice of chain lubes might also be a factor.
    fb
    www.chain-L.com
    The key to solving any problem is to understand and address the underlying cause.
    Yeah I see you saw my X-post from RBR. Yeah it's a medium to high frequency vibration, it's just really pronounced in the crank arms during strong efforts. There is absolutely no perceptible play in the cassette/freehub interface, nor in the bottom bracket crank interface. It's definitely not a click or creak. I hope you are right about the components wearing together.
    Reputation: cort's Avatar
    Hmm hard to tell without riding the bike, but this seems to be occurring at your power stroke point. I wounder if you are deflecting the crank arm a bit. Any chance you are a big lad? And does this happen only at the extreme ends of the cassette range?
    I would check your limit screw adjustments and see if they need to be "tweaked" a bit for your new set-up (do you use or have a trim feature set-up?)
    Nov 2008
    Cort's advice is spot on. Crank and/or frame deflection can cause the chain to rub the front derailleur cage, usually in the highest gear or gears, since the deflection will be towards the outside. Check trim and/or adjust the outer limit slightly.
    I omited this advice earlier, since I assumed an experienced rider would recognize the sound and feel of an out of trim FD.
    fb
    www.chain-L.com
    I'm not a big guy (5'10" & 155 lbs.) and I am certain it's not the FD--I'm a very experienced mechanic. It's is most definitely happening during the time of maximum force application to the pedals. I agree with FB, the drive train components probably need to wear together a bit. Keep in mind that the crank is designed for 10 speed and I am using a 9 peed chain, cassette etc. I also feel the chain line is off a bit, but to my knowledge, there is no way adjust the shimano crank. I'll ride it for a while and see if it improves. Thanks for the insights!
    Reputation: D.F.L.'s Avatar
    What you're describing sounds like the vibration you feel through your feet, but don't really hear. It feels like the drivetrain isn't meshing properly, right? Like a slight popping?
    If it's not too expensive, try a Shimano chain. It makes no sense, but when I was wrenching I found that the SRAM 9 speed chains were somehow not completely compatible with all Shimano cassettes. I can't make sense of it, but after a few unsuccessful SRAM installs, I gave up trying to put a SRAM chain on Ultegra cassettes. I asked my fellow mechanics, and they had the same experience. No such problems with the off-road cassettes and I always run SRAM chains on XT cassettes.
    (and now a few replies stating that SRAM chains and Shimano cassettes are perfect together...)
    I picked up a shimano Durace-XTR chain and put on my bike. Apparently there is a difference: althought the vibration is still there, it is much more subtle. The shifting is also markedly improved. Go figure! It was $15 cheaper then the Sram hollow pin chain too. I had to to do the same thing on my mtb a year ago, the sram chain didn't play well with my xt cassette. It seems like the last batch of shimano 9 speed cassettes don't play well with sram chains. Oh well, still using the power link though!
