Results 1 to 9 of 9
    Why are chain guides so expensive and what do I need to keep my chain in place?
    First, just as an observation, chain guides and chain retention devices seem a bit overpriced. I cannot justify spending $150 for a chain guide. But that is a small complaint.
    I am running 1x9 on a hardtail. The frame has ISCG 05 mounts. I currently have a bashguard on the outside, but my chain keeps falling to the inside. What sort of set-up do I need in order to keep it in place? What would be considered overkill?
    Reputation: Nater's Avatar
    Re: Why are chain guides so expensive and what do I need to keep my chain in place?
    N-Gear Jumpstop works well on hardtails if you're running a bash ring (as you are). Google it...I think they're about $12.
    Sent from my SCH-I500 using Tapatalk 2
    Bicyclochondriac.
    THIS^^^^
    I know for some really rough applications, this might not work, but I've been running the bash/jumpstop combo on a HT for about 4 years and the only time I've ever lost a chain was when the jumpstop got knocked out of alignment in a crash. Other than that, not a single chain drop. Not one.
    Just make sure you shorten the chain as much as much as you can.
    Why are chain guides so expensive and what do I need to keep my chain in place?-p1010009.jpg
    Reputation: honns's Avatar
    Some put a bashguard on both sides of the chainring, making a bashwich. Though the above suggestion is also likely to solve your problem.
    Bicyclochondriac.
    Quote Originally Posted by honns View Post
    Good point!
    I think the bashwich idea is very elegant when it fits, because it also provides protection from the chain coming off all the way around the chainring, rather than in just one place. However, it won't fit on all bikes. I wanted to do this on the bike pictured, but a 32t bash in the small ring position could not clear the chainstay.
    Te mortuo heres tibi sim?
    Third on the N-gear bit. Cheap, light, works well. Jump Stop + un-ramped ring (if you've not already got one) and bash on the outside works very well in most cases on hardtail.
    Many years of riding all sorts of chunky and rowdy trails on my hardtails, and that setup worked very well with on the once in a very rare derailment.
    $12 plus $6 shipping for a 1/16th inner BBG bashguard. Give it a try - works great and looks good.
    Reputation: WolfTooth's Avatar
    All good suggestions. If you want the lightest, best looking solution, you could also try one of our Drop-Stop chainrings. They are designed to work with clutch-type rear derailleurs but we have been doing some experimenting with non-clutch and it is working well so far. Obviously will never be as reliable as with a clutch-type but for 9-speed, you don't really have that option.
    May or may not suit your needs/budget but it is an elegant solution compared to some others...
    wolftoothcomponents.com
    Reputation: tyrebyter's Avatar
    Running an E13 XCX I05 on a 9 speed hard tail with a Zee RD. Yes you can run 9 speed with a clutch: 9 speed SRAM shifter with Shimano Dynasys RD. No bash, never drops a chain. Drive train Nirvana.
  1. Holy crap chain guides are expensive.
    By srey in forum General Discussion
    Last Post: 02-02-2013, 11:49 AM
  2. Chain skipping- new rear derailer, cable chain and cassette already in place
    By Master Obiwan in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-26-2012, 08:06 AM
  3. Chain guides
    By Isis01 in forum General Discussion
    Last Post: 02-29-2012, 08:08 PM
  4. chain guides ?
    By sean connaghan in forum Turner
    Last Post: 06-20-2011, 12:47 AM
  5. 1 x 9 chain guides
    By Flboy in forum All Mountain
    Last Post: 02-14-2011, 07:40 PM
Hot Deals
Contests
Latest Mountain Bike Articles
