Results 1 to 13 of 13
    Who is using a Shadow Plus 10-spd derailleur with a SRAM 9-spd shifter?
    Looking to hear about how well this works and how it's done. If you haven't done this, or know someone who does, move along - I don't want to debate why I want to do this. Thanks!
    Mar 2011
    Interesting article about drivetrain hacks - one guy uses a 6mm spacer on the 10speed XTR RD cable pinch bolt which slightly increases the travel per click of the RD to match the 1:1 SRAM 9 speed instead of the 1 and a bit to 1 of dynasys. He claims it works fine - I was thinking of trying it out myself
    Hacks: SRAM / Shimano Drivetrain Mix & Match Special Edition
    Thanks that helps... looks like there's a great photo of it here:
    in Kensington, Maryland, United States - photo by jwick - Pinkbike
    More here:
    Dyna Sys 10 speed compatability with 9 speed (Shimano systems)
    If you get the thickness right (1/4"), it sounds like it works as good, or even better!!! than SRAM 9-speed shifter with a SRAM 9-speed derailleur. Pretty interesting.
    Mar 2011
    One word of caution - it's virtually impossible to quantify "works fine" - a trail buddy (who is a right masher and breakks things at least once a month) is running a 10 speed XT RD shadow+ with 10 speed SRAM twisties (unmodified) and he thinks it's fine - everyone else who's tried his bike (myself included) think it shifts like S**t - rattles about and seems to take ages to catch, in the low gears - It's his bike I want to try this on - smaller spacer than 6mm though
    Plays with tools
    Reputation: customfab's Avatar
    No, just no.
    I am.
    I had to make a shim to make it work properly. You can see my picture under the sticky on the subject at the top of the drivetrain forum. Dated 4/2/12 about 16 pages in. Some folks said you did not need to do anything but I found that this was not the case as the pull ratios did not match properly. Can't take the interweb as gospel don't cha know. I am very picky about shifting so I developed a solution for my needs.
    I too have friends that mix-n-match components and say stuff works. I hate riding with them as they really only can use only a few gears as the rest are ching and skip. They are happy so good for them. Everyone has different expectations so I understand.
    Quote Originally Posted by Stevoo View Post
    I am. I had to make a shim to make it work properly.
    I've been using this setup for a few months and it works great. My drivetrain shifts just as precisely as before but with far less chain slap. I made a spacer similar to Stevoo's (thanks Stevoo!) and switched out my 9-speed X9 RD for an XT 10-speed Shadow Plus RD. Everything else remains 9-speed. Shifters are 9-speed X9 triggers.
    psycho cyclo addict
    Reputation: edubfromktown's Avatar
    Setup a M986 XTR Shadow Plus 10-speed rear derailleur with a SRAM X0 9-speed shifter on a new hard tail build and it shifts quite nicely. I used a 6mm shim. The primary reason is that I have a lot of 9-speed gear that I want to continue using (for a lot of reasons) and wanted to eliminate chain slap in style
    Who is using a Shadow Plus 10-spd derailleur with a SRAM 9-spd shifter?-screen-shot-2013-07-26-26-jul-7.20.57-am.jpg
    Mar 2013
    I'm using an XT 770 shifter and a drilled SLX 675...
    Attached Thumbnails Attached Thumbnails Who is using a Shadow Plus 10-spd derailleur with a SRAM 9-spd shifter?-strokedrd-m675.jpg
    Drilled?
    Mar 2013
    yep and poked the cable through the holes closer to the pivot as per 9 spd.
    Reputation: TahoeBC's Avatar
    Slick custom made spacer, mine should be arriving next week.
    For those that were interested in the 9-10 speed rear derailer adapters
    The spacer arrived, very well made and works perfectly! Highly recommend!
  1. Sram 8 speed trigger shifter/ derailleur compatibility .
    By jn23 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-10-2013, 03:47 PM
  2. Replies: 67
    Last Post: 12-24-2012, 01:16 PM
  3. Will my Sram X5 shifter work with XT 772 Rear Derailleur?
    By MattC555 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-09-2012, 02:03 PM
  4. Shimano Deore derailleur work with Sram X-7 shifter?
    By wantadhbike in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-06-2011, 04:05 PM
  5. New Rear Derailleur for SRAM Attack 8 Trigger Shifter
    By - JMC - in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-06-2011, 03:09 PM
