Results 1 to 7 of 7
    Reputation: bobbotron's Avatar
    Nov 2007
    Where to find a new 9 speed triple crank?
    Hey all,
    I'm helping my sister rebuild her old touring bike, we want to upgrade it to 9 speed to get access to more cassette selection, it's 7 right now with biopace ring'd cranks that are pretty worn out. We could swap the rings on the cranks but it would be nice to get cranks with the correct chainring spacing. Could any of you direct me to where I could get a NOS 9 speed crank? The only one's I've found are very low end shimano, a FSA vero crankset (that get's poor review), middleburn (which are quite expensive!) and a sugino 600, which is 8 speed spaced and not ideal...
    Why NOS? Jenson USA has a new Shimano Alivio for $39.99 and it comes as square tapered. Alivio can be considered low end but there's nothing wrong with it unless you're worried about weight. If you are worried about weight then you'll have to spend some cash to get something lighter.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by bobbotron View Post
    Hey all,
    Jenson has at least a dozen 3x9 cranksets. Not all have "3x9" in the description.
    mtbtires.com
    Oct 2011
    Lots of option on the triple cranks. I put a Sugino triple on my old Raleigh road bike, lets me run down to 24t in the small ring and that is set up better for a road/touring bike chain line. Or you can go with a MTB crank, that may shove the chain line out about 5mm..I am running a 9sp. SRAM chain on that bike, although it has a 7sp freewheel in back.
    Some good info below:
    - Harris Cyclery Cranks and Cranksets for Bicycles
    Nov 2007
    Good point. I'm not set on NOS, a new crank would work well too. The rest of the bike is comprised of nicer parts than those alivio cranks, so I was hoping to aim higher.
    Deore is a good price point if you find them on sale. I got a set with bottom bracket a couple of months ago for under $60.
    Just as a FYI, if your rear wheel is a 7 speed freehub, you can't put a 9 speed freehub on it.
    Bicyclochondriac.
    Quote Originally Posted by jlmuncie View Post
    I got an Alivio 9 speed crank for my wife's town bike. It is Octalink. Really nice, IMO.
