Results 1 to 3 of 3
    May 2013
    When to use chain connector pins?
    Hey guys,
    Replacing a chain for the first time and I want to make sure I do things right. Based on what I've been reading it sounds like whenever you join a chain together, you have to use a "new" connecting pin; you can't just pop an old one out and back in after. Shimano and SRAM seem to use different systems, but so far I've got a Shimano SLX HG73 on the way: Shimano SLX HG73 9 Speed Chain | Buy Online | ChainReactionCycles.com
    When should I be using Shimano's break-away connector pins? When I join it for the first time? A new one every time I break and rejoin the chain? Is it arbitrary where I can break/join the chain?
    Mar 2011
    If you need to break the chain in future don't use the connector pin link use a chain tool to pop another pin out and don't push it out all the way; otherwise it's difficult to get back in - just push it so the end of the pin is flush with the inside face of the outer link.
    You can use SRAM 9 speed PowerLinks with Shimano Chains no problem they are a little less hassel
    May 2013
    Perfect, thanks so much SimpleJon. Exactly what I needed. Cheers
  1. Chain pins for shimano.
    By aBicycle in forum General Discussion
    Last Post: 01-05-2013, 10:10 PM
  2. Xtr 10 speed chain, broken connecting pins
    By Rootberry in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-04-2012, 10:21 AM
  3. Link/Chain Connector for 10sp Shimano Chain?
    By Affe in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-09-2012, 02:25 PM
  4. Correct Shimano chain pins for XT chains?
    By duffin in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-07-2012, 10:48 PM
  5. Recommendation for 9-Speed chain with Chainrings without Shift Ramps and Pins ...
    By mtbvfr in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-09-2011, 11:07 AM
