Results 1 to 6 of 6
    Your killing my Strava
    Reputation: vinnyl26's Avatar
    When to replace a cassette
    I have 3,600 miles on my 07 Stumpy. when would be a good time to replace the chain and cassette? It came stock with a Shimano Hg-50, 9spd, 11/34. What would be a good upgrade? Same with the chain. What do you recommend?
    Former Bike Wrench
    Measure the chain stretch with a tape measure or ruler pin to pin
    12" new
    12 1/16" replace chain
    12 1/8" likely need to replace cassette too
    12 1/4" look at a whole new drivetrain
    Quote Originally Posted by mtnbiker72 View Post
    12" new
    I am at 12 1/4" why a whole new drive train?? Rear derailer and front sprockets too??
    Former Bike Wrench
    If you allowed your chain to wear out this much, you other drivetrain components have also worn this much. You may only have to replace individual chainrings depending on if you spend most of your time in one or two. Putting a new chain on these very worn chainrings can often lead to skipping and chainsuck.
    By drivetrain I was not referring to the derailluers, though you might check the condition of the pulleys.
    Ok I think tomorrow I will get a new chain cassette and middle and small front chain rings,,,any recommendations for a cassette
    Former Bike Wrench
    Cassettes often depend on what type of hub you use and if weight is important. If you have a hub with a steel freehub body (Shimano or similar) and weight isn't an issue then the Shimano HG61 is a very solid and durable cassette. If weight is a concern and/or you own a premium rear hub with an aluminum freehub body then a Shimano XT or SRAM PG990 cassette is a wise choice.
    Chain wise I like KMC X series chains, very strong and durable and come with a quick connect.
  1. Cassette problem, What should I replace with.
    By MRDEUCE in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-08-2009, 01:19 PM
  2. How often do you replace your Chain, Cassette and Chainrings?
    By ExigeS in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-06-2009, 01:00 PM
  3. Newb - need to replace cassette, need help
    By victory01984 in forum Beginner's Corner
    Last Post: 05-02-2007, 08:54 AM
  4. When to replace a cassette?
    By wl11 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-04-2006, 10:45 AM
  5. replace cassette after 4 rides?
    By mahkoo in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-11-2005, 07:12 PM
