Results 1 to 3 of 3
    What's up with BMX and MTB bottom brackets?
    Hello from Old Cannondale Super V guy - just trying to upgrade the old square tapered axle bottom bracket, without changing the cranks.
    Being a weight weenie, I see that there are a ton of titanium bottom brackets out there that are marketed to BMXers, names like Box, Token and Sinz. They appear to be the same as any other 1.37" X 24 thread bottom bracket, 68mm to 73mm housing width. I need a 113mm axle, which seems to be no problem. Could save 7 ounces over my old bb.
    Will one of these "BMX" bottom brackets fit a standard 24 thread mountain bike bottom bracket?
    Positively negative
    Those are mostly meant for Mini and Junior bikes, basically kids. Might be fine for putzing around but just getting a Shimano unit might be a better choice.
    Reputation: J.B. Weld's Avatar
    There are 2 slightly different spindle taper standards and I'm not sure if most bmx cranks are the same as shimano or not.
    I brake for stinkbugs
  1. G*D D**M Bottom Brackets.
    By Cracked Headtube in forum Frame Building
    Last Post: 09-22-2016, 10:30 AM
  2. 100 mm Bottom Brackets
    By wieczorek24 in forum Fat bikes
    Last Post: 07-14-2015, 07:56 AM
  3. Bottom brackets
    By JT102 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-19-2012, 03:05 PM
  4. Bottom Brackets
    By romeslipslide in forum Beginner's Corner
    Last Post: 08-10-2012, 07:45 AM
  5. Bottom Brackets: 1 CK or 4 XT?
    By 007 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-14-2011, 10:46 AM
