Results 1 to 3 of 3
    May 2005
    Weird Crank Issue
    OK, so the other day I hit the trail go about 2.5 miles in and notice that my left pedal feels like it was bent or something. I get offa my bike and check the pedal, everything looks and acts fine. I get back on and start to pedal away and my left crack falls off, my bud finds the screw about three feet behind me on the trail.
    After examination I notice that there does not appear to be any lock tite on the screw, and the screw appears to have been stripped. I then try several times to re-attach the cracnk and of course that does not last very long.
    Has anyone ever experienced anything like this before?
    born again
    Reputation: gearz's Avatar
    Quote Originally Posted by burncycle
    Sounds like the screw wasn't properly torqued in the first place. Locktite shouldn't be used on crank screws. If the crank threads are stripped you're SOL and likely need a new crank.
    Classic Cascade Rides
    Original quote by Pinchflat:
    The faster you go the shorter the ride!
    Mantis, Paramount, Campy
    Reputation: Shayne's Avatar
    Yes, That Happens
    The crank bolts will back themselves out from regular use if you dont re torque them from time to time. The wobbling pedal is a dead giveaway to stop pedaling and either fix it or walk home. If you ride with it loose you will eventually damage the crank/ bb spindle interface.
    I've have never had a crankbolt strip on me so I don't know what caused that (perhaps improper install??)
  1. Greasing bottom bracket spindle?
    By Belfrey in forum Tooltime
    Last Post: 07-24-2005, 11:09 PM
  2. 2005 Bianchi GUSS owners. crank bearning issue
    By F5000sl in forum Singlespeed
    Last Post: 05-25-2005, 10:01 AM
  3. 4 crank questions
    By peteer01 in forum General Discussion
    Last Post: 05-13-2005, 11:12 AM
  4. Shock woes - really weird issue
    By freeriderB in forum Downhill - Freeride
    Last Post: 06-01-2004, 08:51 AM
  5. What's the white goop on my bb spindle?
    By Spoiler in forum General Discussion
    Last Post: 02-19-2004, 11:16 AM
