Results 1 to 9 of 9
    Spice
    Dec 2008
    URGENT!! X.9 shifters compatible with Alivio front mech?
    hey
    need to know as soon as possible for a ride tomorrow, becuase my alivio shifters have just broken
    are the x.9 shifters compatible with the alivio front deraileur?
    thanks for the help
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    fronts are 1 to 1 , should work fine .
    Former Bike Wrench
    Yes but X.9 is nine speed and Alivio shifters means you have (or had) a 8 speed drivetrain...are you replacing the drivetrain and rear derailleur too?
    Spice
    Dec 2008
    cheers guys
    mtnbiker72, i was planning on upgrading everything to x.9 at once, sometime next week, but it's been delayed because the chainrings i was going to get are out of stock.
    i'll just change the front shifter for now, i'll change the rear deraileur and the rest of the drivetrain all at the same time when the rings get in stock, just need a front shifter that works for now!
    cheers again guys
    Nov 2008
    The X.9 left shifter is micro-index, so it's compatible with just about anything. Understand that for better or worse your front will no be index, and will require (or allow) trimming.
    fb
    www.chain-L.com
    The key to solving any problem is to understand and address the underlying cause.
    Former Bike Wrench
    Quote Originally Posted by FBinNY
    The trigger is micro-indexed?
    Or are you just referring to the X-9 Twist shifters?
    Nov 2008
    Quote Originally Posted by mtnbiker72
    --- No, though I think they're compatible for the front, but I wouldn't bet on it without confirmation.
    And yes, I was referring to the twisters.
    fb
    www.chain-L.com
    I ran it; it will be fine.
    -Don "LordDRIFT" Draper.
    Former Bike Wrench
    It would be cool if they were like Campy Ergo Power road levers
