Results 1 to 6 of 6
    Feb 2010
    Upgrading Derailleur; need advice.
    Hi guys, I currently have a Jamis Trail X3. I'm looking, in a month or two, to upgrade the rear Derailleur. I currently have a Shimano Deore rear Derailleur.
    I ride mainly on the streets however I will it hit the trails.
    Any advice as to what I should upgrade to?
    2009 Jamis Trail X3 -- 1700 MILES AND COUNTING!
    Mods: Avid BB5s, Kenda K-Rads
    2009 CCM Torrent -- POS
    Former Bike Wrench
    Any particular reason to upgrade?...I ask because looking at the specifications on that bike, your not going to see any significant increase in performance by upgrading the rear derailleur.
    if the current DR isn't broke but just isn't shifting well, try new cables instead. if you are dead set on a new RD, you'll need to keep it ti Shimano. Sram will not work. That being said, SLX, old stock LX or, the highest I'd go, XT. Just look for a good deal on one.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by 2QWK4U
    Save your money. Replace the derailleur only if it breaks or wears out.
    mtbtires.com
    Bicyclochondriac.
    I'm with the others here. You will see no real benefit in upgrading the RD, unless it is broken or just worn out (which takes a LONG time to happen). If you really need to upgrade something, the shifters will make a bigger difference, but if you are having any problems shifting now, you likely just need an adjustment and/or new cables and housing.
    Feb 2010
    Thanks for the advice. I guess I'll wait when(hopefully never) it brakes.
