Results 1 to 1 of 1
    Mar 2013
    upgarding 13' Rockhopper comp crankset ??
    Long story short, found out my 2nd gear is bent and shop will probably not warranty it as it's been 2-3 weeks since bough it, might argue that it is something I did. Anyway if they can't/ won't warranty it looking to upgrade the crank set and bottom bracket. I was at the LBS the guy in the work shop suggest Shimano Deore,Is this a worth while upgarde or should I spend more?
    I notice the teeth count is different from my stocker how will this change things. What's funny is I went on Shimano website and only see cranksets for 10 speeds. Do they not make 9 speeds stuff anymore or something?
    I am open to suggestions as well. I'm just getting in to the sport and still learning. I would like to get a chain guard/bash guard as well.
    Also since my cassette is 9 speed, the deore are 10 speeds...are they compatible? 10 speed chains are different size (gears are cut deeper than 9)
    Stock : 44/32/22, steel
    Shimano: 42 32 24
    Edit: I have a 2013 Rockhopper Comp 29er. All stock other than pedals.
    CRANKSET
    SR Suntour XCR, 9-speed, Octalink
    CHAINRINGS
    44/32/22, steel
    BOTTOM BRACKET
    Shimano, Octalink spline, cartridge bearing, 73mm
  1. Rockhopper fsr comp or stumpjumper fsr comp
    By JoeVic in forum General Discussion
    Last Post: 04-02-2013, 05:46 PM
  2. RockHopper Comp 2011 VS RockHopper 2012
    By JayClaire in forum Specialized
    Last Post: 03-02-2012, 08:31 PM
  3. 2001 Rockhopper Pro vs 2010 Rockhopper Comp 29er?
    By redpointist in forum Beginner's Corner
    Last Post: 10-21-2011, 05:11 PM
  4. 2010 Rockhopper Comp vs 2011 Rockhopper
    By FL_rider in forum Specialized
    Last Post: 08-20-2011, 01:23 PM
  5. 2010 Specialized Rockhopper Comp vs 2011 Rockhopper
    By FL_rider in forum Beginner's Corner
    Last Post: 06-28-2011, 02:38 PM
