    Nov 2008
    Ultimate 29-er Gear Guide for Spinners
    When I bought my new 29-er I spend lot of time thinking about best possible gears. The results are great and I'll happy to share my experience. I know that all mashers will laugh at this recommendation missing all the high gears . Let me describe how I got to my perfect gears it was rather through excluding all wrong choices... FYI, I used Sheldon calculation for gears with 29x2.25 tires.
    First I looked at SRAM XX1. Love the idea of simplicity and weight saving. However, I found out that the range is not good enough for me XC spinner type. Even with 28 chainring, lowest gear is not low enough. 28/42 @80RPM gives you 7.4 km/h. I consider even lower speed worth of biking (rather walking). I know that you need it very rarely but when you are climbing over 20% ascent in the Alps for few kilometers, lower gear is very useful. Last but not least, as you have only 11 gears, so the jumps between high gears are too big to keep optimum pedal frequency.
    So clearly lowest gear needs to be 22/36, which gives you 6.8 km/h @80RPM. And even if you frequency of pedaling goes little down, still worth to stay on bike. One point: I know that there is option also for 20 chainring. However, it is quite non-standard and it is mechanically tricky to fit it on 64BCD cranks.
    So now about high gear. No need for triple chainring 2x10 gives you plenty of high gear. Typically with granny of 22, the cranks come with 36 and so with typical cassette with smallest ring of 11, you have 36/11 and that gives you 45.6 km/h @100RPM. Unless you are racing this is more than enough. What I found out that even 36 is too much and I changed to 33 chainring that gives me 41.8 km/h, which is just perfect. Additional advantage is that I use 33 chainring most of the time and change gears just through real derailleur with perfect range - with granny just for few extreme situations.
    Last but not least, I found out better spaced lower gears with Shimano cassettes, which provide11-13-15-17-19-21-24-28-32-36. (SRAM cassettes have 11-12-14-16-18-21-24-28-32-36) I spend most of the time in the middle of casette and 17-19-21 gears feels much better than 16-18-21.
    Hope that this was useful. Let me know your experience!
    This is very similar to what I've been thinking (with help from the Sheldon Brown website). I'm in the process of moving from a 26/38 double chainring configuration to a triple chainring 24-32-bash setup that I previously used without the bash guard (had a 11-32 cassette at that point, too). I'm now running a 11-36 Shimano cassette, so I think I'll end up with the "bail-out" low gearing that I'm looking for, without losing any meaningful gears (for my riding style) at the top end. I also think that I'll be riding the 32 tooth chainring a lot more for all-purpose riding, with the granny there in reserve.
    Thanks for sharing your thoughts.
    Nov 2008
    32 chain-ring also works well - my choice of 33 was simply as I have SRAM cranks and they have 33 as standard. Granny 24 is OK - but if you climb really long steep, 22 becomes really handy :-)
    I hear ya, Premeks -- will consider moving to a 22 tooth small ring in the future.
  1. The Delaware Trail Spinners
    By godsang in forum Trail Building and Advocacy
    Last Post: 07-27-2012, 08:05 PM
  2. e.thirteen guide, any issues with granny gear mounts?
    By jbourne84 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-08-2012, 06:25 PM
  3. N-Gear Jump Stop Chain Guide what size clamp to order
    By drivengsxr1000 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-22-2011, 07:36 PM
  4. Delaware Trail Spinners' Swap!!
    By Sinker in forum New York - New Jersey
    Last Post: 03-12-2011, 12:20 PM
  5. Down tube hose and gear cable guide
    By J273 in forum Specialized
    Last Post: 01-16-2011, 07:32 AM
