Results 1 to 10 of 10
    Binned
    Nov 2008
    Two wheelsets, two different cassette sizes, chain length issue?
    I'm building a medium duty AM wheel set to use for more technical stuff when I am riding out of my area. My current XC wheel set has an 11-32 cassette on it and I'd like to mount an 11-34 cassette on the AM wheel set. Will the 2 extra teeth on the lower geared cassette (11-34) cause a short chain length concern?
    For use on a FS frame with 100mm travel.
    Reputation: Hoban's Avatar
    Oct 2012
    I doubt it, especially if you don't cross chain it. Be easy to try, though.
    You do have a spare chain anyway, right?
    Binned
    Nov 2008
    Quote Originally Posted by Hoban View Post
    I already figured I'd have to be weary of cross chaining if this could work. I do have other chains but I'm hoping to avoid having to go through that much effort each time I change wheel sets.
    Thanks for your reply.
    Plays with tools
    Reputation: customfab's Avatar
    Depends on how you sized your chain. If you went big/big plus 2 links like SRAM suggests you'll be on the edge of disaster. This is why I absolutely do not like their method, it doesn't allow for very big gear changes. Depending on what your suspension design does to chain length it may or may not cause more problems. You'll need to check chain length once you've got the new cassette on regardless.
    Binned
    Nov 2008
    Quote Originally Posted by customfab View Post
    I did indeed go with the shorter chain length, probably the SRAM method meaning that I need to be cautious about severe cross chaining while rolling over the humps and bumps. I found that adding the two additional links (1 narrow, 1 wide) to make it longer was just too sloppy for my drive train. I guess I should blame this on the chain stay length of the frame I'm riding.
    I think you're correct. I guess I'll just use the same geared cassette on both wheels sets. Thanks!
    Trail Tire TV on blogger
    Reputation: thomllama's Avatar
    Oct 2007
    it's a little odd, but you could if using quick connects (sram or KMC) just use a small add on chain piece and 2 quickies. Basically size to the smaller and then make a little 2-4 link whip with the extra quick connect. Only issue is diff wear but as long as you switch out reasonably often it wont be an issue.
    Going to try and bring Trail Tire TV back. go take a look... http://trailtiretv.blogspot.com/
    Get a longer RD cage?
    Plays with tools
    Quote Originally Posted by Hawg View Post
    That's a completely unnecessary compromise.
    Reputation: shiggy's Avatar
    Dec 1998
    Size the chain for the 34 and be done with it.
    I swap between wheels with 11-34 and 11-28 cassettes (double front, medium cage RD) with no issues using the longer chain on the smaller cassette.
    mtbtires.com
    It's a 1/2 inch pitch chain. So the extra 2 teeth should increase the circumference of the cog by 1 inch. Since the chain only wraps around about half of the cog, I figure you would need 1/2 inch more chain. I'll bet you will hardly even be able to see the difference in your chain slack.
  1. Cassette sizes
    By Jim_bo in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-11-2013, 07:14 AM
  2. picking chainring and cassette sizes for a 1x9
    By bryan.gurc in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-24-2013, 05:53 PM
  3. Replies: 16
    Last Post: 04-04-2012, 05:39 PM
  4. will my chain length be fine changing from 11-32 to 11-34 cassette?
    By ussprinceton2004 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-24-2011, 09:51 PM
  5. Running Two Wheelsets - Cassette Questions
    By punkrocknj in forum 29er Bikes
    Last Post: 06-06-2011, 10:54 AM
