Results 1 to 3 of 3
    Reputation: Dmytro's Avatar
    Nov 2003
    Two quick questions
    Hey guys, 2 more quick questions:
    1) How freely should a newly installed bottom bracket spin? Here is a video of what mine is like. Shimano ES-51. http://www.guilded.net/personal1/dri...2/MVI_1797.avi
    2) Do I have my rear derailleur installed correctly? Is my B-Tension screw in the correct position?
    Thanks!!!
    -> SickLines.com <-
    Reputation: mtb_biker's Avatar
    it looks like your rear derailluer limit screw is not set right. If you have instructions for your shimano rear derailleur that will help you setting up the b tension screw. You set teh btension screw based on largest gear.
    Old man on a bike
    Your high limit screw doesn't seem to be set correctly from the photo. It's not possible to see whether your b tension screw is set correctly (it's basically making sure your upper pulley isn't touching the the largest cog, you need to have the chain installed, too). Check your low limit screw, too.
    suum quique
