    Truvativ Hussfet Isis Worn Out
    Hello,
    I have some play between my crankset and my bottom bracket (ISIS Hussefelt). It is obviously the crank arms that are worn out, but I was wondering: should I change the cranks only or the BB too?
    The aluminum of the cranks worns easy when they were untight, but does the cromo axle do too? I mean this is something I cant see by eye only, I guess, and there are so much forces at this very spot that it could have consequences on the new cranks even if the axle is slightly worn. Am I right?
    Yes, I think so.
    Also check the BB bearings for wear as well.
    Meh.
    Reputation: XSL_WiLL's Avatar
    All tapered spindles will eventually wear out.
    Since you're already replacing the cranks, might as well replace the BB too. Have you thought about outboard bearings at all? Something with a pinchbolt design like the Shimanos? This eliminates the pitfalls of ISIS.
    Thanks guys,that's what I thought, but isn't the BB for this crank already an outboard one? It is a Howitzer XR.
    Now that I am going to change, I'm thinking about getting a FSA GAP or gravity. Those look good, simple and with less parts that can move. Anybody ever tried one of these?
  1. SPAM: Truvativ SS Cranksets, GXP, ISIS
    By 32sixteen in forum Singlespeed
    Last Post: 02-16-2006, 06:25 AM
  2. Which ISIS crank/bb- FSA or TruVativ?
    By gregk in forum 29er Bikes
    Last Post: 04-04-2005, 06:17 AM
  3. New crankset, which version: Truvativ Stylo Isis or X-grid
    By tom traynor in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-12-2005, 05:13 PM
  4. Are Truvativ isis cranks 8spd compatible?
    By Wazzou in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-20-2004, 12:36 PM
  5. Just broke a cup on my bont. truvativ ISIS, which one should I get
    By walle1jm in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-28-2004, 06:58 PM
