Results 1 to 6 of 6
    Oct 2007
    Truvativ Howitzer
    Hey guys,
    Im going to run a 1x8 on a current fs build. Im planning to use a truvativ hussefelt and a howitxer bb. I have no idea what size BB i need. I was told howitzers work with 68 and 73, but there are other sizes EX 68/73-56. What does the fifty six stand for? How do I know what kind I need? Thanks in advance
    bored ex-shop rat
    Reputation: velopax's Avatar
    Caution;  Merge;  Workers Ahead!
    The Howitzer has 136mm spindle with 51mm chainline and 148mm spindle with 56mm chainline.
    Manual
    Oct 2007
    How do I know which one I need?
    bored ex-shop rat
    The standard chainline is most 51mm, measured middle ring to center of seattube.
    You plan to use a chain guide of any kind? Check the manual of the guide, some guides
    need a longer spindle, if you use 1 "big" ring? There is sometimes not enough clearence
    at the chainstay.
    Oct 2007
    What chain guide do you guys recommend?(cheap)
    bored ex-shop rat
    Good job!
    Truvativ Box Guide Link
    OK e13 and Blackspire are very nice, but much more expensive
