Results 1 to 11 of 11
    Reputation: fishercat's Avatar
    Truvativ crankset small ring size question
    I have an X9 3x10 crankset on which the smallest ring (granny) is 22T. I have removed the big ring and replaced it with a bash guard. The 22T is too small, I am used to shimano which uses 24T. Is it possible to replace just my 22T ring with a 24T or do I have to replace the whole crankset ? LBS told me I could replace the ring but my bike wouldnt shift well, that the manufacturer designed it to be a 22T. I wouldnt mind switching to shimano but I would have to replace my BB as well, so that is a last resort. Please advise. thanks
    gone walk about
    Reputation: nvphatty's Avatar
    Mar 2012
    I'm guessing the remaining rings are 22/32 and the change making it 24/32 correct? yes you can replace the spider ring and it will shift a bit diff from what your accustomed too but nothing extreme.
    "ORANGE IS THE NEW BLACK"
    The White Jeff W
    Reputation: jeffw-13's Avatar
    Re: Truvativ crankset small ring size question
    Ill have to check the parts box when i get home. I might have a 24 tooth off a Truvative Stylo crankset that you can have. It would have the shift ramps on it that wouldnt be on a regular ss 24 tooth ring
    No moss...
    cool. would this fit on my crankset. I'm pretty sure its a 3x10.
    The White Jeff W
    I dont see why not.
    No moss...
    great. let me know if you have it, that would be great.
    The White Jeff W
    I will. I wont be home till late tonite so ill let you know tomorrow
    No moss...
    Bicyclochondriac.
    Quote Originally Posted by jeffw-13 View Post
    Granny rings don't have shifting ramps.
    The White Jeff W
    Well, i suck. Checked the spare parts & it turns out i dont have a 24. Sorry for that
    No moss...
    The White Jeff W
    Quote Originally Posted by kapusta View Post
    I know. Just wanted to see if u were paying attention
    No moss...
    Hey thanks for checking ! I'm sure I can find one somewhere
  1. Replies: 0
    Last Post: 03-28-2013, 11:45 AM
  2. Replies: 14
    Last Post: 05-01-2012, 12:16 AM
  3. Can I put the small ring (22) from an M542 Crankset onto a Deore XT M781 crankset?
    By bobonker in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-09-2012, 12:04 AM
  4. SLX Chain Ring on Truvativ Stylo crankset
    By AndesJack in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-19-2011, 11:12 AM
  5. 24T Small Ring on a XT M785 Crankset?
    By davemk in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-19-2011, 10:05 AM
