Results 1 to 6 of 6
    Truvativ cranks - attachment issue, torque?
    I have a set of Truvativ Holzfeller cranks with the Truvativ BB. I just assembled a new DJ bike with this crankset. Build went together fine, but when I tighten the cranks the BB binds and does not turn easily. When I loosen them, it feels fine; but the cranks are not tight enough to ride. I am not excessively tightening the cranks, so what's up? Did I screw up on the number of spacers needed for the BB (73mm)? Any help here would be appreciated.
    Dirt Deviant
    Reputation: savagemann's Avatar
    How DID you set the spacers up?
    Calm Like a Bomb
    Reputation: pipes10's Avatar
    one spacer on the drive side for a 73mm
    is your bb shell faced properly?
    is the crankstop/seal in place?
    manual for howtizer
    http://www.sram.com/_media/techdocs/...itzer-e-r0.pdf
    '17 Hatchet Carbon
    '17 Troy Carbon
    '16 Django Carbon
    '16 Wilson
    '16 Farley 5
    https://www.instagram.com/jayparrington/
    Re
    Yes, I have the one spacer on the drive side for a 73mm. The crankstop/seal is in place. I did not get the bb shell faced. Could that be the problem?
    Calm Like a Bomb
    it could be...u could be side loading the bearings....do the cups look like they are in straight with no gaps (even if they do it;s always good to face the shell)
    '17 Hatchet Carbon
    '17 Troy Carbon
    '16 Django Carbon
    '16 Wilson
    '16 Farley 5
    facing
    It looks fine, but I might as well get it done (I hope that is it!)
