    Jul 2013
    Trek 820 - Is this right?
    My brother-in-law picked up a Trek 820 (2006) off of Craigslist and in going over it, it seemed that the gap between the left crank and the bottom bracket is a bit wide. The bottom bracket is firmly seated in the frame and the distance from the edge of the frame to edge of the crank is about 3/8". There is no play in the bottom bracket. If this is too wide of a gap, should the crank be able to seat further in on the bottom bracket?
    Greg
    Trek 820 - Is this right?-820_1.jpgTrek 820 - Is this right?-820_2.jpgTrek 820 - Is this right?-820_3.jpgTrek 820 - Is this right?-820_4.jpgTrek 820 - Is this right?-820_5.jpg
    Reputation: J.B. Weld's Avatar
    That looks about right, 3/8 gap between the crankarm and chainstay is within normal parameters. Make sure to torque that bolt to spec before your ride, which is pretty darn tight if you don't have a torque wrench.
    Re- read your post and realized I missed where you were getting the 3/8 measurement from. Spindle length determines where the crankarms and chainrings in relation to the frame. I can't tell from that pic if the spindle is the right size or not, but I'm guessing it is.
    Jul 2013
    Thanks for the replies.
  1. Help Deciding! Trek Wahoo 29er vs. Trek 4500 Disc MTB
    By Zantikus in forum Bike and Frame discussion
    Last Post: 07-06-2013, 08:17 AM
  2. Replies: 4
    Last Post: 04-22-2013, 10:35 AM
  3. 2011 trek 3500 vs 2007 trek 4300 vs 2008 trek 4300
    By TreyTRD in forum General Discussion
    Last Post: 03-23-2013, 09:56 AM
  4. Replies: 28
    Last Post: 06-25-2012, 07:03 PM
  5. Replies: 9
    Last Post: 08-22-2011, 08:05 PM
