Results 1 to 7 of 7
    Inspector Gadget
    Reputation: abeckstead's Avatar
    Feb 2012
    Torx bit size SLX crank?
    Anyone know which size torx is needed to remove the arm on a SLX crank? My local stores don't have any big enough... Want to order it online.
    Thanks for any help
    I hope you have a big trunk... cause I'm gonna put my bike in it!
    Jan 2011
    It usually will say on the bolt itself. But the ones I have seen are usually t30. If all else fails call Shimano...
    Home depot sells a set of torx bits for your socket wrench. these have covered most things I've worked on(bikes and cars). You'll end up needing more then one size sooner or later anyway.
    Reputation: PerthMTB's Avatar
    I assume you're talking about the black plastic pre-load nut on the non-drive side, not the chainring bolts. If so, you can get the special tool from any bike store for a couple of bucks, or search online for "Shimano TL-FC16"...
    It's deliberately made of plastic, and without any spanner/socket interface, so you can't over-tighten the nut and ruin the BB bearings. It should only be done up finger tight, or 1Nm if you want to get technical and have a torque wrench that goes that low
    Jan 2011
    Quote Originally Posted by PerthMTB View Post
    As you said I assume you're talking about the black plastic pre-load nut on the non-drive side, not the chainring bolts. If so, you can get the special tool from any bike store for a couple of bucks, or search online for "Shimano TL-FC16"...
    duhhhh!!!! that's what i get for trying to post while half asleep lol
    Inspector Gadget
    Feb 2012
    Thank you!
    Plays with tools
    Reputation: customfab's Avatar
    A lot of the time you can get them out with a pair of snap ring pliers or needle nose. Like Perth said they're not that tight so if you're in a pinch you can get them off with a variety of things.
  1. BB size and crank width
    By tims5377 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-07-2013, 09:13 AM
  2. what size crank arms?
    By goodmojo in forum Beginner's Corner
    Last Post: 01-01-2013, 09:00 PM
  3. Trance x BB/crank size?
    By giant_in_a_trance in forum Giant
    Last Post: 07-04-2012, 01:08 PM
  4. Crank size help
    By endlesssummr026 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-07-2012, 07:03 PM
  5. torx bit size for disc rotors
    By jmstu76 in forum 29er Bikes
    Last Post: 06-14-2011, 08:03 PM
