Results 1 to 3 of 3
    Sep 2004
    top swing vs bottom swing
    I have had a lot of problems with my chain not dropping off my middle chainring to my small one. I have a 22/32/44 set. I have been through 2 sets of chainrings and several chains and cassettes and put in an XT FD. I have tried toeing in, toeing out, bending the cage and have lowered the FD derailleur as low as I can go. It just seems that I can't seem to get the derailleur close enough to the middle chainring to put enough side pressure on the chain to get it to consistently shift into the small ring. If there is very little pressure it is fine, but even a small amount of pedal pressure causes me headaches. I have to be extremely cautious of my downshifts. Anyway, my question is this, does a bottom swing derailleur have a swing arc that would bring the cage closer to the middle ring?
    Mantis, Paramount, Campy
    Reputation: Shayne's Avatar
    Sounds More Like A Chainline Issue
    I think a longer BB spindle would probably take care of that issue.
    On the topic of TS vs BS derailleurs I much prefer the performance of bottom swing derailleurs.
    Sep 2004
    I have thought about increasing the spindle length but the chainline was perfect when measured. But I will be replacing the BB soon anyway and perhaps a longer spindle length will put a little extra side tension on it. I think if that doesn't help much, perhaps a bottom swing would be my next choice.
  1. Front derailleur - top swing, bottom swing?
    By pwrplay27 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-16-2014, 01:14 AM
  2. Replies: 67
    Last Post: 03-01-2005, 07:03 AM
  3. Front derailleur - top swing or bottom swing better?
    By dodger in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-10-2004, 08:01 AM
  4. top swing or bottom swing?
    By ryan123 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-24-2004, 02:57 PM
  5. If you could use either top or bottom swing F. der. which would you choose and why?
    By DCepp in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-13-2004, 06:46 AM
