Results 1 to 7 of 7
    top swing or bottom swing ?
    hey guys, this prob belongs in the beginner's corner, i just acquired a K2 brass monkey 2002 model and need a front derailleur, was looking at a shimano xtr or xt, i know its a top pull... 31.8 i believe, but what swing type do i need? confused, just want to be sure i get the right part...thanks!
    ~Disc~Golf~
    Reputation: highdelll's Avatar
    You need a top pull
    The swing can be of either type
    Personally, I think the top swing looks cleaner
    *edit - you may want to get a top swing anyways to avoid possible interferrence between the clamp and a bottle cage on the seattube should you have one there. (or want to later)
    Honestly... ahh I give up
    thanks man, this helps me a lot!
    btw, there is no bottle cage on the seat post tube...
    ~Disc~Golf~
    Quote Originally Posted by KrackerG
    yeah, I was goin off of this 2001 pic
    I guess they took the mounts away for 2002?
    yeah, thats the bike. thanks again!
    i also dont have that "cool" front fender...
    the catalan connection
    Reputation: What&son's Avatar
    yes and no
    I like top swing better too,as Highdelll says looks cleaner and I think it shifts better too... BUT recently switched to a narrower chainline crankset and the derailleur wasn´t dropping the chain to the small cog as good as before. Yes, I checked the barrel adjust and nothing improved. With a down swing derailleur I wouldn´t have had this problem becouse the cage has not the movement inwards limited by the clamp as a top swing does.Finally had to "shape" the outer cage a bit...
    Just a point to consider.
    Cheers
    "Blessed is the man who, having nothing to say, abstains from giving us wordly evidence of the fact." George Elliot
    yea, i thank you guys for your advice, i just got a Shimano LX M580 9 speed front derailleur , i just need something that works, and works well. ...not making a race bike, just a street cruiser, thanks again for all your help!
