Results 1 to 3 of 3
    May 2013
    New question here. Token bb92 pressfit & cranks with no integrated axle
    Is there any way to use cranks without integrated axle (octalink standart) with Token bb92 pressfit bottom bracket (also supports octalink axles, but comes without one)?
    I suppose it should be possible but I don't think it exists. Why do you say the Token supports octalink axles?
    May 2013
    Maybe I was incorrect. Token bb takes Shimano integrated cranksets with standart 24 mm axle. As described here: http://images.planet-x-bikes.co.uk/v...g?m=1318435783
    So I suppose it theoretically may work with 24 mm octalink spindle, if it exists as a separate part.
  1. Replies: 2
    Last Post: 12-22-2012, 10:01 PM
  2. BB92 Bottom Bracket - Will 68/73mm X-Type cranks fit?
    By Freerider in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-11-2012, 08:37 AM
  3. Shimano Pressfit BB91, BB92
    By rideronthestorm in forum Shimano
    Last Post: 01-01-2012, 06:40 PM
  4. Pressfit 30 and isis cranks
    By ryanhugh in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-16-2011, 09:59 PM
  5. new Token integrated cranks: 784g
    By nino in forum Weight Weenies
    Last Post: 12-27-2007, 12:49 AM
