Results 1 to 31 of 31
    Reputation: Mark_BC's Avatar
    Sep 2012
    Tips for unlinking Powerlink links
    After a little bit of use, those SRAM Powerlinks become very difficult to unlink, especially out in the field with a dirty chain and sore fingers. How do you do it?
    All I am saying is give pizza chants
    Reputation: Gouda Cheez's Avatar
    Feb 2013
    Park tool does the trick for me.
    Plays with tools
    Reputation: customfab's Avatar
    I don't use them in the first place.
    The 10spd links from SRAM are power lock and need a tool to be removed, everything else should be tool free.
    Reputation: crossracer's Avatar
    Yea, get the park tool, you won't regret it. Simply awesome
    Bill
    Sep 2012
    You mean the chain breaker? I have that. So I should basically just leave the powerlinks on there and break the chain somewhere else, and then put on a new powerlink in the new break location?
    Plays with tools
    Are we talking 8/9 or 10 spd chains.
    Sep 2012
    8 spd
    Sep 2012
    Oh this?
    Park Tool Co. MLP-1.2 : Master Link Pliers : Chain
    I'm not bringing that with me.
    Plays with tools
    Squeeze the side plates together and then push the halfs towards eachother. If they're worn enough that they aren't coming apart easily I'd replace them as they are probably worn out.
    Feb 2013
    Quote Originally Posted by Mark_BC View Post
    Oh this?
    It's pretty small... for what it's worth. I carry mine in my Camelbak amongst several other tools.
    Apr 2005
    Out of curiosity, why do you need to remove a powerlink, or a chain for that matter, on a ride? I take a spare powerlink and a chain breaker when I'm out riding, so I can remove a broken link and replace it. But, I keep those Park pliers in my toolbox at home.
    Justin
    Salt Lake City
    2012 Specialized Stumpjumper FSR Comp 29
    2006 Specialized Allez Expert Double
    > /dev/null 2&>1
    Reputation: Procter's Avatar
    Feb 2012
    Re: Tips for unlinking Powerlink links
    Agree with Authalic - you probably won't need to remove a power link on the trail, only add a new one. So, leave the pliers.
    The pinch-to-remove method is for older 8/9sp links. The Sram 10sp power link can't be removed like that, and, its very hard without the pliers. I was able to do it only once without the Park tool pliers and it took me 20 min of struggling, including stabbing my hand badly with needle nose.
    There may be 10sp kmc links which are pinch-to-remove, not sure though.
    On wuss patrol
    Reputation: Glide the Clyde's Avatar
    Quote Originally Posted by authalic View Post
    Ever blown up a free hub body, causing it to lock up and the geared bike becomes a fixie, which doesn't work so well with a rear derailleur? I, at least, have and removed the chain so I could coast/scooter back to the trail head. Power Link or chain breaker works to get the chain off on a ride.
    OP, get the stupid Park pliers and put them in whatever you carry tools in. I personally can squeeze the side plates and push the link together with my fingers but it sounds as if you struggle with it.
    Sometimes, you need to go fast enough that the trail is a blur to find clarity. -- Wild Bill
    Sep 2012
    Yeah I guess there is no reason to remove the link while on tour. If the chain breaks somewhere I'll add another link or two where needed. But I'm not bringing the pliers with me, I have totally loaded my bike up with bikepacking gear. I even cut my toothbrush n half.
    No issue on 9speed KMC missing link but when I changed to 10 speed, then unlinking becomes a problem. Manage to do it on 1st time, but failed on the next attempt. After an hour of struggle, gave up and search the net and found one solution without using a special tool. Need to use a straw rope or any string that can go inside the chain hole and a 4/5mm hex wrench to twist the rope/string. Insert the rope/string on both hole of the missing link. Then tie it tightly but leave a bit of space for the wrench to go in. Once its tied, insert the wrench and start twisting until the link disengage. The tightening of the string squeezes both end of the missing link thus unlinking it.
    More Torque
    Reputation: Diesel~'s Avatar
    Quote Originally Posted by Ka_Noli View Post
    I tried that on a 10 speed sram link with a pretty beefy piece of copper wire, and the wire ended up breaking.
    The Park master link pliers will make you laugh the first time you try them, if you've been struggling with a tricky link. SO effortless.
    -D
    dwt
    dwt is offline
    Reputation: dwt's Avatar
    +1.
    Another home shop or trail removal technique is to clean and lubricate link with good old WD40 or similar product. Link hard to move by hand if gunked up. But the Park link pliers are easiest method
    Old enough to know better. And old enough not to care. Best age to be.
    Reputation: Vespasianus's Avatar
    Quote Originally Posted by customfab View Post
    What he said. 100% true.
    On MTBR, the reputation is infamous.
    Reputation: Reign2Rider's Avatar
    If you arn't already, have a look on the side of your chain tool for the hook thing. You hook it onto chain a few links away either side, making a loop that hangs down, it makes dealing with the link much easier. I struggled at first but can get it off in seconds now. Was aligning things yesterday and prob had the chain off 20+ times.
    Plays with tools
    Quote Originally Posted by Reign2Rider View Post
    That looks like a great way to make a simple problem more complicated.
    Erm, yeh real complicated. Just hooking the chain with the hook from your multitool really adds to the complexity of the issue. Much easier to fight with it until your fingers bleed.
    Quote Originally Posted by Diesel~ View Post
    -D
    Yes, copper wire will break as it has a breaking point once it reach a certain angle. So far I have use that works were old LAN cable ( the twisted pair inside of it) and an old shoe lace. So those using laced shoes in the trail, you know you have a secondary use of your shoe lace
    Plays with tools
    Just drop it off the chainring, then you've got all the slack you need.
    Reputation: DJ Giggity's Avatar
    Isn't that the theme of this whole thread?
    Only two infinite things exist: the universe and stupidity. And, I am unsure of the universe
    - Albert Einstein
    LOL @ the bolt-cutters!
    I find the little hook (mine is part of a Topeak multi-tool) most useful to re-fitting the chain when it's a real pain getting it through the front mech as it flops about and won't cooperate. I agree about the pliers being great for home but not being required on the trail - you can use the chain splitter from your multi-tool in an emergency.
    I run 2 chains and swap over every few weeks so the Park Tool is excellent for that.
    Reputation: ColinL's Avatar
    Feb 2012
    Quote Originally Posted by ddprocter View Post
    The KMC ten speed missing link is definitely not removable by hand, and in fact it takes a lot of force to snap it in place when it's brand-new.
    MTBR Member
    Reputation: ncfisherman's Avatar
    Quote Originally Posted by ColinL View Post
    I removed one last week by hand -- it can be done. That is not the case for SRAM powerlinks though.
    Give it a crank
    Reputation: Mtn-Rider's Avatar
    May 2010
    On the trail, just use the chainbreaker, no need to carry more tools. At home, channel lock pliers will do the trick.
    <img src="http://gallery.mtbr.com/data/mtbr/500/SRAM_0002.jpg">
    dwt
    dwt is offline
    Quote Originally Posted by ncfisherman View Post
    Can be done, but those suckers are tight. The first time I used one, I thought it was defective cuz I couldn't get it to fasten. With the Park tool for removal, they literally can fly apart.
    Plays with tools
    Quote Originally Posted by Mtn-Rider View Post
    Maybe that's why I've seen so many broken quick links?
    I could unlink sram powerlink 9sp and kmc missinglink 10 sp by hand. Basically just squeeze both sides and slide. Harder when it is so dirty. Search youtube. I saw the video awhile back, as I was struggling too.
  1. Best price on Teva Links or Links Mid?
    By GTscoob in forum Where are the Best Deals?
    Last Post: 04-05-2013, 09:15 AM
  2. multiple quick links (power links)
    By BmoreKen in forum Singlespeed
    Last Post: 02-12-2013, 11:23 AM
  3. Help with Chain/Powerlink
    By hankscorpio in forum Beginner's Corner
    Last Post: 09-09-2012, 06:01 AM
  4. SRAM powerlink
    By captnpenguin in forum Singlespeed
    Last Post: 08-09-2012, 06:39 AM
  5. sram powerlink
    By Eric Z in forum Beginner's Corner
    Last Post: 07-15-2011, 07:29 PM
