Results 1 to 13 of 13
    Nov 2008
    Time ATAC Squeak
    Anyone having trouble with time ATAC pedals squeaking on their shoes?
    I have both ATAC XS Carbons & ATAC Alums and Shimano M086 shoes. Both sets of pedals squeak with the shoes.
    Any ideas?
    - J. Ryan
    Quote Originally Posted by tread29 View Post
    Any ideas?
    Make sure your cleat bolts are tight and the cleats aren't coming loose. After that, check the bottom of your shoes - do they have grooves worn into them from the wire bales? If so, check the pedal body directly under the cleat for scrapes/wear marks between the wire bales on both sides of the pedals. Is it getting scraped up? That's what is causing it. Once the grooves wear deep enough into your shoe sole, the bottom of the cleat hits the pedal body and rubs it which creates a squeaking noise.
    Nov 2008
    Quote Originally Posted by steiny View Post
    I took a few minutes last night and took the cleats off, cleaned them thoroughly, put a tiny bit of grease on the screws and put them back on. I clipped them onto the pedals and moved them around a bit and I didn't hear any squeaks. I'll be commuting home tonight with the ATAC alums. I should know if the cleaning worked by the time I get home.
    If the cleaning doesn't work I'll take a look at the pedal body. The shoes are starting to get grooves.
    - J. Ryan
    mountain biker
    Reputation: slyfink's Avatar
    I find this happens when the conditions are dry. all my buddies with Times have noticed the same thing. it's something we've all come to live with.... fortunately, things don't usually stay dry here very long...
    continuous growth is the strategy of a cancer cell.
    Reputation: jkirkpatri's Avatar
    ALL of my Time's have squeaked. New shoes, new cleats, new pedals or old shoes, old cleats, old pedals - they all squeak.
    The only Time's that don't squeak are the ROCs. Having tried the ROCs for one year, I'm back to the basic Time Carbons. Yes, I get squeak, but the ROCs were just too different (too much side to side play for my liking).
    Hopefully somebody can chime in with a fix. I know I've been looking for a fix for years. Lube on the pedal's bars helps, but only for one ride, so not a long term fix.
    Afric Pepperbird
    Reputation: dirt farmer's Avatar
    Mar 2005
    Put a drop of chain lube inside the rubber washer. That always works for me.
    Quote Originally Posted by dirt farmer View Post
    Rubber washer on the spindle?
    Afric Pepperbird
    Mar 2005
    Quote Originally Posted by jkirkpatri View Post
    This here
    <!-- copy and paste. Modify height and width if desired. --> <a href="http://content.screencast.com/users/dirtfarmer/folders/Jing/media/74e86172-50ba-439b-b356-e16bfe5ba478/00000001.png"><img class="embeddedObject" src="http://content.screencast.com/users/dirtfarmer/folders/Jing/media/74e86172-50ba-439b-b356-e16bfe5ba478/00000001.png" width="695" height="440" border="0" /></a>
    It's not exclusive to carbon only, I might add.
    ^ that's what I was figuring that you were refering to. I'll give that a shot today.
    Reputation: BrokenBones's Avatar
    Feb 2005
    I recently switched over to ATACs after nearly a decade on Eggbeaters. When it was cold and damp outside, my rubber shoe lugs would squeak on the Eggbeater wings. I hate squeaks and creaks! The last few evening rides it's been chilly in the 40's and the ATACs have started to squeak. I thought it may be a temperature issue too. I'll try the drop of lube on the rubber bushing. Thanks!
    'Bones
    Plays with tools
    Reputation: customfab's Avatar
    Quote Originally Posted by BrokenBones View Post
    You put up with crank brothers pedals for that long, impressive
    The little rubber seal does seam to be the most common squeak for me in the last ~13 years of time usage.
    Nov 2008
    This here
    Unfortunately that isn't' the source of the squeaking on my carbons. I took them off the bike, clipped them onto the shoe, and was able reproduced the squeaking by shifting the pedal around on the shoe.
    I discovered some vertical play between them. Specifically the metal bar of the pedal can slide vertically between the sole of the shoe and the protrusion of the cleat.
    Maybe the metal bars on my pedals are just worn too much and need to be replaced?
    - J. Ryan
    Reputation: Coldass's Avatar
    This here
    Exact place I get squeaks on my loved Time's (the older skinny spindle versions didn't do this). I just squirt some silicon spray lube and wipe off excess. Never had shoe noise - and I have had Time's since 91'...
  1. What's the difference between Time ATAC XS or ROC ATAC?
    By JayF in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-05-2009, 10:30 PM
  2. Difference between Tima Atac Roc Carbon and Time Atac SX
    By Danish Dynamite in forum General Discussion
    Last Post: 02-14-2009, 08:49 PM
  3. Time ATAC XS Carbon vs. ATAC XS
    By MrXC in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-15-2007, 01:14 PM
  4. Time Atac Alium vs. Atac XE
    By MightyTurtle in forum Beginner's Corner
    Last Post: 11-11-2006, 07:15 PM
  5. Do time atac and the newer atac XS pedals use the same cleats?
    By Jonboy99 in forum General Discussion
    Last Post: 07-25-2005, 06:33 AM
